Transition Bikes SMUGGLER Größe M Rahmenkit inkl. RockShox Monarch RT3 Debonair Rear Shock -
1.399,00 € VHB
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
06.11.2018 19:05
Endet
07.11.2020 14:15
Angesehen
878 ×
Anzahl
Hersteller
Transition Bikes
Zustand
neu
Abholung
Ja
Farbe
schwarz oder orange
Rahmengröße
M
Laufradgröße
29"
Händler
Ja
Land
Deutschland de
Sattelstützendurchmesser
31,6 mm
Dämpfer-Einbaumaße
Sonstige
Akzeptierte Bezahlmethoden
Banküberweisung
Lieferumfang
Transition Bikes 2016: SMUGGLER Rahmenkit
The all new Smuggler takes the 29er in a new direction with a
short travel platform that isn’t short on versatility. Aggressive
geometry with a slack 67.5 head angle and roomy cockpit let
you push the bike hard while the 29 wheels smooth out rough
terrain. The short 435mm chainstay and 115mm of progressive
suspension keep the bike agile, responsive and playful for
maximum fun on whatever trail you choose.
TRANSITION RIDE IMPRESSIONS
It’s no secret that 27.5 wheels get all the attention these days,
but we haven’t forgotten about the big wheel, and we love the
way they ride when done correctly. We wanted the Smuggler
to give the rider all the benefit of a 29 wheel without any of the
negatives. That is a pretty lofty goal, but we think the Smuggler is
our best 29er ever. The 29 wheel is awesome for traction, control
and confidence, but too much travel or the wrong geo and the
bike will feel sluggish on the trail. Many companies run steeper
head angles or a shorter wheelbase to add agility, but these are
a poor substitute for a proper head angle, weight balance and
room to move around on the bike. Our shorter travel frame gives
you a direct connection to the ground and super short 435mm
chainstay length with stiff rear triangle will make you forget you
are on “wagon wheels”. Push the bike into rough, rooty and
technical terrain and the big wheels do their work to keep you
moving forward and smooth out the trail under you. This bike will
go much further than the travel numbers would suggest.
FEATURES
• Progressive Geometry – Long, Low and Slack
• Giddy Up Link Suspension, 115mm Rear and 130mm Front
• Integrated Rubber Chainstay Protection
• Collet Style Main Pivot Hardware
• ISCG05 Chainguide Mounting, No Front Derailleur Support
• Syntace X12 Rear 142mm Axle and Universal Transition
Derailleur Hanger
• Full Size Water Bottle Fits Inside Front Triangle
• User Friendly 73mm Threaded Bottom Bracket
• Internal Cable Routing, Including Stealth Seatpost
Alle Bikes und Teile können natürlich auch gern vor Ort nach Terminabsprache besichtigt und abgeholt werden!
Sofern nicht anders angegeben, sind die angebotenen Artikel NEU.
Rechnung mit ausgewiesener MwSt. sowie volle Garantie und Gewährleistung gehören natürlich dazu.
Wir realisieren gern individuelle Aufbauten - nicht alle verfügbaren Angebote sind online, Anfragen sind immer willkommen!
Bei Fragen einfach melden!
Viele weitere Angebote findest du im MOUNTAINLOVE Bikemarkt Shop
Versandkosten Standardpakete:
DE ab 4,90€
EU ab 12,90 €
Versandkosten Kompletträder:
DE ab 35€
EU ab 55 €
Zahlung im IBC:
Vorkasse
Paypal (zzgl. 2%)
Nachnahme (zzgl. 8€ Nachnahmegebühr, nur nach DE)
Avatar
Shop
Bewertungen:
1490 (100,0 %)
Verkäufer mountainlove Verkäufer mountainlove
5/5 basierend auf 1490 Bewertungen.
Vertrauen: 37
Antwort in: 14 h
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
