Ultimate stiffness narrow-wide chainring for SHIMANO® M8000 and MT700 cranks.
-The new narrow-wide teeth design increases chain retention, wear life, and reduces friction and noise.
-Lighter weight than shimano steel chainring (~20-30g depending on size).
-Larger wide teeth design provides maximum ring durability and drop performance.
-6mm chainring thickness optimized for maximum stiffness.
SPECIFICATIONS
[table][tr][td]Material[/td]
[td]Machined 7075 T651 aluminum[/td]
[/tr]
[tr][td]Finish[/td]
[td]Anodized[/td]
[/tr]
[tr][td]Colors[/td]
[td]Black Blue Red Green[/td]
[/tr]
[tr][td]Range[/td]
[td]30T 32T 34T 36T[/td]
[/tr]
[tr][td]Compatibility[/td]
[td]9/10/11 speed[/td]
[/tr]
[tr][td]Size/PCD[/td]
[td]SHIMANO® M8000 96PCD 110°[/td]
[/tr]
[tr][td]Weight[/td]
[td]39g(30T) 58g(32T) 67g(34T) 79g(36T)[/td]
[/tr]
[/table]
