Norco Sight VLT 2 NX Eagle eBike 2019 Größe L
5.999,00 € VHB
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
22.01.2019 11:58
Endet
22.01.2020 11:58
Angesehen
196 ×
Anzahl
Hersteller
Norco
Zustand
neu
Abholung
Ja
64572
Rahmengröße
L
Dämpfer-Einbaumaße
Sonstige
Laufradgröße
27,5" / 650b
Händler
Ja
Land
Deutschland de
Motor
Shimano
Akku-Kapazität
630 Wh
Federweg vorn
160
Federweg hinten
150
Akzeptierte Bezahlmethoden
Banküberweisung
Looks like a Sight, rides like a Sight but ... yeah, we put a motor in it. This is the Sight VLT. There’s nothing better than having fun out on the trails and with the Sight VLT riders will get exactly that – just more of it. We took all of the aggressive all-mountain qualities you love about our pedal Sight and wrapped them into a seamless, extremely capable electric-assist package. The best-in-class Shimano E8000 drive unit and 630 Watt integrated battery give riders the necessary boost to power up the steepest climbs, while modern geometry and optimized suspension kinematics allow them to charge down the rowdiest descents – again and again. Discover a new way to ride with the Sight VLT.
Frame    Sight Carbon 650B 150mm travel
Fork    RockShox Pike RC, 160mm Travel, Boost 15x110mm TA, Charger 2 Damper, E-Bike Rated, 46mm Offset
Rear Shock    Rockshox Deluxe RT Debonair Trunnion mount, custom tune
Headset    Acros block lock ZS-44/56 sealed bearing headset
Headset Spacer    3x10mm  / 1x5mm / 1 x 2.5mm
Grips    Ergon GE 10 EVO black grips
Handle Bar    Norco 20 mm rise 6061 800mm, 35mm bar bore
Stem    Alloy forged 6061 50mm stem
Seat Post    JD TransX YSP-12JL Dropper 100mm S/125mm M/150mm L, 31.6, 1x lever
Seat Post Clamp    Norco design alloy nutted clamp
Saddle    WTB Volt Sport
Front Brake    Sram Guide T w/200mm rotor
Rear Brake    Sram Guide T w/200mm rotor
Shifter Rear    Sram NX Eagle 12 speed
Rear Derailleur    Sram NX Eagle
Cassette    Sram NX Eagle 12 speed cassette 11-50T
Chain    Sram NX Eagle PC12 speed chain
Crankset    Shimano FC-E8000, 165mm w/32T Sram Eagle narrow/wide
Bottom Bracket    Samox 104 BCD Spider for Shimano spline, boost 53mm
Front Hub    Novatec 110x15 sealed bearing disc hub
Front Hub Skewer    axle ( comes with fork)
Rear Hub    DT H370 148x12 Boost sealed w/XD driver E-MTB rated
Rear Hub Skewer    Syntace  X-12 system axle
Spokes/Nipples    Sapim stainless steel butted front, DT Alpine rear
Rims    WTB ST I29 TCS 2.0  27.5
Front Tire    Maxxis Minion DHF 27.5x2.6 EXO/TR
Rear Tire    Maxxis Minion DHRII 27.5x2.6 EXO/TR
Motor    Shimano E8000
Battery     600 W intube
Verfügbarkeit bitte anfragen!
Alle Bikes und Teile können natürlich auch gern vor Ort nach Terminabsprache besichtigt und abgeholt werden!
Sofern nicht anders angegeben, sind die angebotenen Artikel NEU.
Rechnung mit ausgewiesener MwSt. sowie volle Garantie und Gewährleistung gehören natürlich dazu.
Wir realisieren gern individuelle Aufbauten - nicht alle verfügbaren Angebote sind online, Anfragen sind immer willkommen!
Bei Fragen einfach melden!
Viele weitere Angebote findest du im MOUNTAINLOVE Bikemarkt Shop
Versandkosten Standardpakete:
DE ab 4,90€
EU ab 12,90 €
Versandkosten Kompletträder:
DE ab 35€
EU ab 55 €
Zahlung im IBC:
Vorkasse
Paypal (zzgl. 2%)
Nachnahme (zzgl. 8€ Nachnahmegebühr, nur nach DE)
Avatar
Shop
Verkäufer:
mountainlove.de
de
Bewertungen:
1431, 100,0 % positiv
Verkäufer mountainlove Verkäufer mountainlove
5/5 basierend auf 1431 Bewertungen.
Vertrauensstufe: 37
Antwortzeit: 14 Stunden
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
