Preisupdate! Morewood Makulu Frame Bos Idylle/stoy Fabien “cous cous” Cuisine rider frameset
749,00 € VHB
Momentane Betrachter
Veröffentlicht
13.10.2019 12:35
Endet
13.10.2020 12:35
Angesehen
1989 ×
Anzahl
Zustand
gebraucht
Versandkosten
25
Abholung
Ja
Budapest
Farbe
rot
Rahmengröße
M
Steuerrohr
Tapered 1⅛″/1,5″
Dämpfer-Einbaumaße
267 x 89 mm
Bremssattelaufnahme hinten
Post Mount
Laufradgröße
26"
Sattelstützendurchmesser
30,9 mm
Material
Aluminium
Händler
Nein
Land
Ungarn hu
Fabien Cuisine edition custom made MOREWOOD Makulu frameset
It has a custom made frame from Fabien Cuisine (DH racer / team owner of Unitedride) with a special geometry which makes it lower and slimmer than a standard Makulu frames. (You can notice it quite well when used compared to a regular Makulu.) It has a custom candy red color.
The upper tube lighter, it has a redesigned rear axle, the frame has a lower bottom bracket with a flatter head tube angle. In the bottom bracket you will find the “cous cous” engraved which refers to Fabien Cuisine’s nick name.
The frame comes with a
-          BOS Stoy rear shock with a 200lbs, 250lbs and 275lbs springs
-          BOS Idylle rare coil fork with green (under 60kg), orange (between 60-80kg) and a grey (between 80-105kg) spring
-          HOPE headset
-          ISCG 05 consol
-          150x12 rear axle
-          83mm wide bottom bracket house
The frame is in a very good condition
Avatar
Bewertungen:
174 (100,0 %)
Verkäufer Csonge10 Verkäufer Csonge10
5/5 basierend auf 174 Bewertungen.
Vertrauen: 3
Antwort in: 1,6 d
