Norco Range VLT1 eBike 2020 Größe XL
7.999,00 € VHB
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
13.01.2020 21:11
Endet
13.01.2021 21:11
Angesehen
106 ×
Anzahl
Hersteller
Norco
Zustand
neu
Abholung
Ja
64572
Rahmengröße
XL
Dämpfer-Einbaumaße
Sonstige
Laufradgröße
27,5" / 650b
Händler
Ja
Land
Deutschland de
Motor
Shimano
Akku-Kapazität
630 Wh
Akzeptierte Bezahlmethoden
Banküberweisung
The Range VLT 1 is a monster of an e-bike built to smash through tough, burly trails, careen down rock faces, and just go big.
Optional range extender available for purchase soon.
Frame    Carbon 27.5, 170mm Travel, M/L/XL
Fork    RockShox Lyric Ultimate, Charger 2, RC2, 180mm Travel, short offset, E-MTB
Rear Shock    RockShox Super Deluxe Coil Ultimate DH, Trunion
Headset    Acros Block Lock, sealed bearing
Grips    Ergon GE10 EVO, lock on
Handle Bar    Deity Ridgeline, Aluminum, 800mm, 25mm rise, 35mm bore
Stem    Norco 40mm, 35mm bore
Seat Post    BikeYoke Revive Dropper w/Triggy lever, M/L - 160mm, XL – 185mm
Seat Post Clamp    Norco Alloy, Nutted
Saddle    Ergon SM-10 E-Mountain Sport
Front Brake    Sram Code RSC 4 piston, Hydraulic, 200mm
Rear Brake    Sram Code RSC 4 piston, Hydraulic, 200mm
Shifter Rear    SRAM GX Eagle, 12 speed, Single Click
Rear Derailleur    SRAM GX Eagle
Cassette    SRAM Eagle Xglide 1230, 11-50T
Chain    SRAM NX Eagle
Crankset    Shimano Deore XT Hollowtech FC-M8050, 165mm, 32T SRAM Eagle narrow/wide
Bottom Bracket    104 BCD Spider, Shimano spline
Chain Tensioner    e*thirteen Compact Upper Slider
Front Hub    DT H-1700, sealed bearing 15x110mm Boost
Front Hub Skewer/Axle    Comes with fork
Rear Hub    DT H1700, 12x148mm Boost, XD driver
Rear Hub Skewer/Axle    Syntace X-12
Spokes/Nipples    DT E 1700 Hybrid, E-bike rated wheelset
Rims    DT E 1700 Hybrid. E-bike rated wheelset
Front Tire    Maxxis Assegai. 2.5” 3C Maxx Terra, EXO+,TR
Rear Tire    Maxxis Assegai, 2.5”3C Maxx Grip, DD, TR
Motor    Shimano STEPS E8000
Battery    In-Tube Battery, 630Wh
Größe: M, L und XL
Verfügbarkeit bitte anfragen!
Alle Bikes und Teile können natürlich auch gern vor Ort nach Terminabsprache besichtigt und abgeholt werden!
Sofern nicht anders angegeben, sind die angebotenen Artikel NEU.
Rechnung mit ausgewiesener MwSt. sowie volle Garantie und Gewährleistung gehören natürlich dazu.
Wir realisieren gern individuelle Aufbauten - nicht alle verfügbaren Angebote sind online, Anfragen sind immer willkommen!
Bei Fragen einfach melden!
Viele weitere Angebote findest du im MOUNTAINLOVE Bikemarkt Shop
Versandkosten Standardpakete:
DE ab 4,90€
EU ab 12,90 €
Versandkosten Kompletträder:
DE ab 35€
EU ab 55 €
Zahlung im IBC:
Vorkasse
Paypal (zzgl. 2%)
Nachnahme (zzgl. 8€ Nachnahmegebühr, nur nach DE)
Avatar
Shop
Bewertungen:
1502 (100,0 %)
Verkäufer mountainlove Verkäufer mountainlove
5/5 basierend auf 1502 Bewertungen.
Vertrauen: 37
Antwort in: 14 h
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
