Felt Redemption E-30 E-Bike Fully 2019 Shimano Step Neu
3.699,00 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
14.02.2020 08:11
Endet
14.02.2021 08:11
Angesehen
76 ×
Anzahl
Hersteller
Felt
Zustand
neu
Abholung
Ja
Rahmengröße
Other
Dämpfer-Einbaumaße
Sonstige
Laufradgröße
27,5" / 650b
Händler
Ja
Land
Österreich at
Akzeptierte Bezahlmethoden
Banküberweisung
E-Bike, E-Mountainbike, Fully
Modell 2019
Grau
Verfügbare Größe: 16", 22"
Aluminiumrahmen
Frame:
Felt All Mountain, 150mm travel, Shimano e-Bike specific, double-butted 6061 aluminum, fully integrated down tube, ControlTaper integrated head tube, post disc mount, replaceable derailleur hanger, 12 x 148mm Syntace style thru axle
Shock:
Rock Shox Deluxe R, Debonair, 185 x 52.5mm Trunnion
Fork:
Rock Shox Yari RC Solo Air, 150mm travel, 15 x 110mm Boost, E-Bike specific
Headset:
FSA sealed cartridge bearings, semi-integrated, No.57, 1.125 - 1.5"
Stem:
Devox, ±7° rise, Ø31.8mm with Cr-Mo bolts, 35mm
Handlebar:
Devox E-MTB 6061 butted riser, Ø31.8mm, 25mm rise, 9° sweep, 780mm wide, custom internal wire routing
Grips:
Devox Pauley Grip
Shifters:
Shimano SLX M7000, 1x11
Rear Derailleur:
Shimano XT, 11-speed, Shadow Plus, long cage
Crankset:
Shimano E8050, 34T, SM/MD/LG: 170mm, XL: 175mm
Chainguide:
MRP E-Guide
Bottom Bracket:
Shimano e8000 MTB drive, 250W output, 20 mph
Battery:
Shimano E8020, 500Wh integrated
Chain:
KMC X11-E, 11-speed
Freewheel / Cassette:
Shimano SLX, 11-speed, 11-46T
Brake Levers:
Shimano
Brake (Front):
Shimano SLX M7000 hydraulic disc, 203mm rotor
Brake (Rear):
Shimano SLX M7000 hydraulic disc, 180mm rotor
Saddle:
WTB Volt Race, Cr-Mo rails
Seatpost:
KS LEV Integra dropper with South Paw, Ø30.9mm, SM: 100mm travel, MD: 125mm travel, LG/XL: 150mm travel
Seatpost Clamp:
Felt single bolt, Ø34.9mm
Rims / Wheelset:
WTB Scraper i35, tubeless compatible, 35mm inner width
Front Hub:
Shimano Deore, 15 x 110mm Boost thru axle, Center lock, 32H
Rear Hub:
Shimano Deore, 12 x 148mm Boost thru axle, Center lock, 32H
Thru Axles:
Rear: Felt leverless 12 x 148 x 166L Syntace style, thread: M12 x 1.0
Spokes:
2.0mm butted stainless steel
Tires:
Maxxis Minion DHF front, Maxxis High Roller 2 rear, 3C/EXO, tubeless ready, 27.5 x 2.8"
Accessories:
Battery charger
Finish (Accent):
Storm Grey / Black
Weight:
51.2 lbs.
UVP: 4999.-
Hier um 3699.-
Avatar
Shop
Bewertungen:
531 (95,7 %)
Verkäufer Deusmagnus Verkäufer Deusmagnus
5/5 basierend auf 531 Bewertungen.
Vertrauen: 5
Antwort in: 29 min
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
