Nukeproof Digger 275 Factory Bike Größe: L
2.849 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Wir sind Ihr NUKEPROOF Händler für Deutschland, Österreich und Schweiz.
VERSAND MÖGLICH - DIESER ERFOLGT KOMPLETT MONTIERT UND EINGESTELLT.
The high-performing Digger Factory Bike is engineered for adventures and is inspired by Nukeproof's athletes and their desire for a do-it-all training bike with something a little extra. It features a robust aluminium frame that's triple-butted for maximum strength as you ride from A to B and everywhere in between. Coming equipped with the capacity to add panniers, bike racks and mudguards, this model is perfectly suited for everything from commuting to work to big adventures in the wilderness.
  • Frame: Nukeproof Digger 27.5” Road Plus or 700C compatible, Hydroformed 7046 Triple-Butted Aluminium, internal cable routing for dropper seat posts, threaded bottom bracket, 142mm x 12mm rear axle spacing
  • Fork: Nukeproof Digger carbon, 27.5” Road Plus or 700C compatible, High Modulus T700 HM-UD Carbon Tapered Steerer, Rack Mounts, 12x100mm axle spacing
  • Axle to Crown: 400mm
  • Fork Offset: 45mm
  • Front Wheel: DT Swiss G1800 SPLINE 25, 27.5", 12x100mm
  • Rear Wheel: DT Swiss G1800 SPLINE 25, 27.5", Shimano freehub, 142x12mm
  • Wheel Size: 27.5" (Will accept 700Cx42C)
  • Tyres: WTB Sendero 650x47C Road Plus, TCS, Light Fast Rolling, Tan wall, Dual DNA Compound
  • Max Tyre Size: 27.5"x47C/700Cx42C
  • Crankset: Shimano RX-810, GRX, 1x 11 Speed, 170mm, 40T
  • Protection: Kevlar Chainstay Protector
  • Brakes/Shifter: Shimano GRX, RX-810 Levers with RX-810 Flatmount Callipers
  • Front Rotor: Shimano RT800, 160mm
  • Rear Rotor: Shimano RT800, 160mm
  • Rear Derailleur: Shimano GRX, RD-RX812, 11 Speed, Shadow Plus
  • Chain: KMC X11 11-Speed, Anti-rust with Quick Link
  • Cassette: Shimano CS-M8000 XT 11 Speed, 11-42T
  • Handlebars: Non Series AL-6061 480/500mm
  • Stem: SRAM Zipp SC, 6 deg, 80-110mm
  • Stem Lengths: 50cm:70mm /52cm:80mm/ 55cm:90mm/ 58cm:100mm
  • Saddle: Nukeproof Horizon SL, Black
  • Seatpost: Brand X Ascend internal, 125mm drop, 31.6mm, Dropper lever integrated into GRX RX-810 Brake Lever, Internal Routing for Dropper Seatpost
  • Seat Clamp: 34.9mm
  • Headset: Nukeproof Warhead Internal, IS42-28.6 - IS52.1/40
  • Bottom Bracket: Threaded 73mm BSA
  • Bar Tape: Black Cork Cushion Tape with Gel
  • Weight: 9.68Kgs/21.3lbs (Tubeless)
Änderungen und Irrtümer vorbehalten. Abbildungen ähnlich.
Es gelten die unsere AGB´s
automatisch übersetzt
2.849 €
Bike Performance Dresden de Gewerbliche/r Anbieter*in
Antwort in: 1,1 d
Bewertungen: 12 (67%)
Vertrauen: 0
Momentane Betrachter 1
Veröffentlicht 21. Jan 2021 18:42
Endet 5. Feb 2024 12:25
Angesehen 4.471 ×
Anzahl 1
Hersteller Nukeproof
Zustand neu
Abholung Ja
Ort Dresden
Rahmengröße L
Händler Ja
Land Deutschland de
Gewicht 9.68Kg
Farbe Artichoke Green
Material Aluminium
Akzeptierte Bezahlmethoden PayPal, Überweisung
