Specialized Roval Control SL, 29
Bewertungen:
1 (100,0 % )
Verkäufer BBasta
5 /5
basierend auf 1 Bewertungen.
04.09.2018
Vertrauen:
Antwort in: 12 h
Momentane Betrachter
Veröffentlicht
20.09.2021 20:28
Endet
20.09.2022 20:28
Angesehen
2.059 ×
Anzahl
Hersteller
Specialized
Zustand
gebraucht, wie neu
Versandkosten
30
Abholung
Nein
Karlovac
Gewicht
1240 g
Laufradgröße
29"
Laufradtyp
Laufradsatz
Farbe
satin-carbon
Felgentyp
Carbon
Montagestandard Bremsscheibe vorn
IS 6-Loch
Montagestandard Bremsscheibe hinten
IS 6-Loch
Anzahl Speichen Vorderrad
24
Anzahl Speichen Hinterrad
24
Felgenbreite
29
Nabenbreite vorn
110 mm
Nabenbreite hinten
148 mm
Achsdurchmesser Vorderrad
15 mm
Achsdurchmesser Hinterrad
12 mm
Material
Carbon
Tubeless/Tubeless Ready
ja
Händler
Nein
Land
Kroatien
Specialized ROVAL CONTROL SL, 29 6B XD, driven 800 km Rim Type: Carbon clincher, 2Bliss Ready, Zero Bead Hook 4mm FlatTop design. Cobalt Blue Metallic graphic under clear coat, Not compatible with tire inserts. Rim Material: Carbon fiber Rim Width: 29mm internal Front Spoke Pattern: Two-cross Rear Spoke Pattern: Two-cross Spoke Count: 24h Front, 24h Rear Spoke Type: DT Swiss Aerolite Straightpull T-head 294mm Nipple Type: DT Swiss Pro Lock Hexagonal Alloy 14mm 2.0mm Front Hub: Alloy body, 15mmx110 thru-axle, 19 and 31mm OD end cap options included. Max Rotor Size <200mm Rear Hub: CNC-machined alloy body, SiNC Ceramic Bearings, premium-quality DT 180 internals and 54t quick engagement ratchet system cassette, includes SRAM XX1 11-speed freehub and 148 end caps. Max Rotor Size <200mm Roval Engineered Control SL hubshells have a single spoke length for each wheelset. Bearing Type: SiNC Ceramic Sealed cartridge Assembly Method: Hand-built Every wheel includes custom anodized tubeless valve stems and individual spoke hole plugs to make tubeless set-up easier. Total Wheelset Weight: 1240g
