Specialized Enduro evo 27.5 grösse m boxxer wordcup
Nur paar mal gefahren kleine Lackplatzer vom Transport. Entgegen der original Austattung ein Boxxer worldcup 200mm Gabel, Sram NX Eagle 1x12 Schaltung, Shimano Saint Bremsen
Original Schaltung kann mitgegeben werden.
Wegen Umstieg auf 29"
Originale Technische Spezifikationen
FRAMESET
FRAME
M5 aluminum, 650b EVO geometry, tapered headtube, PF30 BB, ISCG ‘05 mount, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 180mm travel
HEADSET
1-1/8 and 1-1/2"" threadless, Campy style upper with 1-1/2"" lower, cartridge bearings
SEAT BINDER
Specialized 7050 alloy, single bolt, 34.9mm
WHEELS
FRONT HUB
Specialized Hi Lo disc, sealed cartridge bearings, 20mm thru-axle, 32h
RIMS
Roval DH 650b, alloy, 24mm inner width, w/ eyelets, 32h
REAR HUB
Custom DT Swiss, Star Ratchet, XX1 driver body, 12mm thru-axle, 32h
SPOKES
DT Swiss Industry, stainless
SUSPENSION
FORK
RockShox Boxxer Team 650b, coil spring, tapered alloy steerer, high/low-speed compression and rebound adj., 20mm thru-axle, 180mm travel
DRIVETRAIN
REAR DERAILLEUR
SRAM X0 Type 2, 10-speed, short cage
CASSETTE
SRAM PG 1030, 10-speed, 11-36
SHIFT LEVERS
SRAM X9, 10-speed
CHAIN
SRAM PC 1031, 10-speed, w/ PowerLink, nickel finish
CRANKSET
Custom SRAM Descendant, PF30 spindle, alloy arms, 165mm, 36T ring, w/ Gamut bashguard
BOTTOM BRACKET
SRAM, PF30, OS press-in bearings, sealed cartridge
COCKPIT
STEM
Specialized P.Series MTB, forged alloy, 4-bolt
GRIPS
Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XL
HANDLEBARS
Specialized Demo, low-rise, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 31.8mm
SEATPOST
Thomson alloy straight, 12-degree clamp
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
2.200,00 €
Bewertungen: 5 (100%)
Vertrauen: 1
Momentane Betrachter 1
Veröffentlicht 10.04.2022 12:40
Endet 10.04.2023 12:40
Angesehen 1.530 ×
Anzahl 1
Hersteller Specialized
Zustand gebraucht
Abholung Ja
Ort 63834
Rahmengröße XS
Dämpfer-Einbaumaße 190 x 40 mm Metric
Laufradgröße 26"
Händler Nein
Land Deutschland de
