Nukeproof Reactor RS 275
Nukeproof reactor 275 RS, MY 2020, size M
The bike has a different shock: EXT Storia LOK V3
A new front tire
A new hollow pin chain
Below is the original specification:
Frame: Nukeproof Reactor 275 Carbon, 140mm Travel, UD woven Carbon Fibre front triangle/chain stays/seat stays, internal cable routing, custom tuned rear shock, Enduro bearings, threaded bottom bracket, boost 148mm rear axle spacing, 3D contoured frame protection
Fork: RockShox Lyrik Ultimate Charger 2 RCT3 160mm, 46mm Offset, BOOST, Debonair, Gloss red
Shock: RockShox Super Deluxe Ultimate RCT, Custom ML 380 tune, 210x55mm, Bearing End (Comes with 1x bottomless token fitted so you have them if needed.)
Front Wheel: Mavic Deemax DH, 27.5", 6 Bolt, 110x15mm
Rear Wheel: Mavic Deemax DH, 27.5", 6 Bolt, XD Driver, 148x12mm
Tyres: Front: Maxxis Assegai 27.5”x2.5 WT 3C MaxxTerra/EXO+/TR, Rear: Maxxis Minion DHR II 27.5”x2.4 WT 3C MaxxTerra/EXO+/TR
Crankset: SRAM X1 Carbon Eagle 12-Speed, 170mm, 32T, B148, DUB
Shifter: SRAM XO1 Eagle 12-Speed, Red
Rear Derailleur: SRAM XO1 Eagle 12-Speed, red
Chain: SRAM GX Eagle 12-Speed
Cassette: SRAM XO1 Eagle 12-Speed, CS PG1295 Eagle 10-50T
Brakes: SRAM Code RSC
Front Rotor: SRAM Centreline, 200mm
Rear Rotor: SRAM Centreline, 180mm
Handlebars: Nukeproof Horizon Carbon 25mm Rise, Width - S780mm, M780mm, L800mm, XL800mm)
Stem: Nukeproof Horizon, 50mm, black
Saddle: Nukeproof Horizon SL, red
Seatpost: RockShox Reverb Stealth with 1x Remote, 31.6mm; S: 346mm length, 125mm drop; M: 409mm length, 150mm drop; L: 462mm length, 175mm drop; XL: 514.5mm length, 200mm drop
Headset: Nukeproof, 44-56 IITS
Grips: Nukeproof Sam Hill Signature
automatisch übersetzt
3.100 € VHB
uhp si
Bewertungen: 5 (100%)
Vertrauen: 0
Momentane Betrachter 1
Veröffentlicht 28. Dez 2022 23:51
Endet 28. Dez 2023 23:51
Angesehen 1.775 ×
Anzahl 1
Hersteller Nukeproof
Zustand gebraucht, wie neu
Versandkosten 100
Abholung Ja
Ort Ljubljana Slovenia
Farbe grey
Rahmengröße M
Federweg vorn 140 mm
Federweg hinten 160 mm
Steuerrohr Tapered 1⅛″/1,5″
Dämpfer-Einbaumaße Sonstige
Laufradgröße 27,5" / 650b
Material Carbon
Gänge 1x12
Händler Nein
Land Slowenien si
