Production Privee Shan 27 917 limited Edition Rahmen KIT: mit 12x142mm Schaltauge, PP Steckachse und PP Steuersatz
550,00 € VHB
Momentane Betrachter
Veröffentlicht
08.07.2017 16:20
Endet
08.07.2018 16:20
Angesehen
407 ×
Anzahl
Hersteller
Production Privee
Zustand
neu
Versandkosten
nach Absprache
Abholung
Ja
Mannheim
Gewicht
2,6 kg in Größe M
Farbe
hellblau/ orange
Rahmengröße
L
Steuerrohr
1 1/8 - 1,5 tapered
Bremssattelaufnahme hinten
Post Mount
Laufradgröße
27,5" / 650b
Sattelstützendurchmesser
30,9 mm
Material
Cromo DB 4130 Japan seamless MCS
Händler
Nein
Land
Deutschland de
Verkaufe meinen neuen, komplett unbenutzten Rahmen, da ich schon beim Auspacken bemerkt habe, dass er mir zu klein ist.
Er wurde lediglich einmal kurz zur Ansicht aus dem Karton geholt.
For 160mm front travel fork, the SHAN 917 is now back in 27 version. The paint scheme in an inspiraion from the famous Porsche 917 of Steve Mcqueen in le Mans movie. Very special edition, all numbered behind the seat tube, production limited to 500pcs world wide. The SHAN 27 is the perfect Enduro weapon when the trail is steep, fast and gnarly.
Frame KIT: 549€ with 12x142mm hangers, PP rear axle and PP headset.
The SHAN 27 917 is probably the most high-end Enduro hardtail on the market. We use for the SHAN a set of cromo 4130 tubes from Japan, triple butted and heatreated before welding. An anti rust layer is applied inside and outside the tubes before painting. The hoses guides are in alloy and screwed on the frame. The 2 tone paint scheme is made by mask (8 layers of paint and clear coating) and a special attention is bring to the finishing of this trail weapon limited at 500pcs world wide.
The key point of the SHAN is the vertical flexibity of the rear end thanks to the KTP flex system. This allows more grip, more comfort and more efficiency in down-hill section! To achieve it we’ve developped our own specific bladed tubes for the chainstays and the seatstays their increase the vertical flexibility. We didn’t use bridge between chainstays for the same idea. The seatstays are not heat treated to allow a maximum flexibility.
To insure the performance of our KTP flex system, we should used high-end tubes. That’s why our SHAN are made with Japanese cromo 4130 triple butted tubing. All tubes are heat treated before welding excepted the seat stay to keep more even flexibility.
We use on the SHAN a tapered head-tube for 2 reasons : better stress distribution between the down-tube and the headtube, thanks to the biggest welding junction and to increase the stifness of the front triangle without adding weight. We use on the SHAN a pressfit bottom bracket because his 92mm wide allow to weld the both chainstay with more clearance around the rear tire while keeping short chain stay.
An ED black treatment is applied inside and outside the tubes to prevent any rust issue and to insure a perfect paint application.
The SHAN 27 is 650B ready but is still built for 150mm or 160mm travel forks. The frame is now delivered with 12x142mm hangers to follow the current wheel offer. However we are still convinced 10x135mm makes a better choice in terms of ride feeling, so 10x135mm hanger kit are available.
The cherry on top is that the Shan can be built with 26" wheels thanks to a optional hanger kit allowing to have the right geometry (available in 10x135 and 12x142mm).
SHAN 917
Use : All Moutain, Enduro, Marathon DH
Wheel size: 650B, can be built with 26" wheels with a specific conversion kit
Fork : from 150 to 160mm travel
Material: Cromo DB 4130 Japan seamless MCS
Heat Treatment : All the tubes except seatstays
Headtube: Tapered, integrated campagnolo 45x45, SHIS: IS42/IS52
BottomBracket : BB92 Press Fit standard (Compatible with 68/73mm crankset)
Rear hangers: removable design and provided with 12x142mm, options kit available please see frame accessories section
ISCG :ISCG 05
Seat post diameter needed: 30.9mm
Seat clamp diameter: 34.9mm
Front derailleur compatibility: 34.9mm clamp diameter / top swing top pull
Weight : 2600g in medium size
Finish: ED treatment before painting
Artwork: Two tones painting
Sizes : S, M, L & XL
Avatar
Verkäufer:
Bergziege98
de
Bewertungen:
Vertrauensstufe: 0
Antwortzeit: 3 Stunden
QR-Code
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
