Marin Bikes Alpine Trail E1 E-Bike Mountain Shimano Steps 2022 Neu
Fotos: Marin Bikes Alpine Trail E1 E-Bike Mountain Shimano Steps 2022 Neu
3.799 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Marin Bikes Alpine Trail E1 E-Bike Mountain Shimano Steps 2022 Neu
Mountainbike
Allmountain-Fully/Trailfully
Auf Bestellung verfügbar. Lieferzeit ca 5 Tage
Marin Alpine Trail E1
Modell 2022
Größe L, XL
Neu
Sonderpreis
FRAME
All New Series 4 Alloy Frame, 150mm Multitrac suspension, Integrated Battery/On-switch/Charging Port, 148mm Rear Thru-Axle, Built-in Rear Speed Sensor
FORK
RockShock 35 Gold RL 29", Motion Control Damper, 160mm Travel, Maxle Stealth Axle, 44mm Offset
SHOCK
RockShock Super Deluxe Coil R, Rebound Adjustment, 205x65mm, 25mmxM8 Lower Hardware, S/M Spring Rate = 300lb, L/XL Spring Rate = 400lb
RIMS
Front: Marin Aluminum Double Wall, 29" Diameter, 32mm Inner Rim Width, Pinned Joint, Disc Specific, Tubeless Compatible; Rear: Marin Aluminum Double Wall, 27.5" Diameter, 38mm Inner Rim Width, Pinned Joint, Disc Specific, Tubeless Compatible
HUB REAR
Shimano HB-MT400B, 148x12mm, Centerlock Disc, Standard Freehub Body
HUB FRONT
Shimano MT-410B, 110x15mm, Centerlock Disc, 32H
SPOKES
14g Black Stainless Steel
TIRES
Front: Vee Tire Co Attack HPL, 29x2.5", Top 40 Tubeless Compatible, Rear: Vee Tire Co Crown Gem, 27.5x2.8”, TACKEE Compound, Tubeless Compatible
DERAILLEUR REAR
Shimano Deore 5100 Direct Attachment, 10-Speed
DERAILLEUR FRONT
SHIFT LEVER
Shimano Deore M4100-R, I-Spec EV, 10-Speed
CRANKSET
Marin Forged Alloy 165mm Length, Narrow Wide 38T Chainring, e13 Plus Chain guide, Aluminum Plate
MOTOR
Shimano STEPS E7000, 250W, 60Nm
CHAIN
KMC X-10E, EBike Specific, Silver
CASSETTE
Shimano Deore M4100-10 10-speed 11-46T
BRAKES FRONT
Shimano MT420, 4-Piston Hydraulic Disc Brake, 203mm Rotor
BRAKES REAR
Shimano MT420, 4-Piston Hydraulic Disc Brake, 203mm Rotor w/ Speed Sensor
BRAKE LEVERS
Shimano MT4100 Hydraulic Lever, I-Spec EV Compatible
HANDLEBAR
Marin Mini-Riser, 6061 Double Butted Aluminum, 780mm Width, 28mm Rise, 5º Up, 9º Back
STEM
Marin 3D Forged Alloy, 35mm
GRIPS
Marin Single Clamp Locking
HEADSET
FSA No 57, Sealed Cartridge Bearings, 1 1/8" x 1 1/2”
SEATPOST
TranzX, YSP23JL, 1x Remote, Size S 125mm Travel, Size M and L 150mm Travel, Size XL 170mm Travel, 30.9mm
SADDLE
Marin eMTB Saddle
PEDALS
Marin MTB Plastic
BATTERY
BT-8035, Internal 504Wh
DISPLAY
SC-E7000 Display
SWITCH
SW-E7000 Left Hand Switch for Assist Mode Change
EXTRAS
Shimano Battery Charger EC-E6002, Bolt-on Thru-Axle
Preis 3799.- statt 4899.-
Modell 2022
Größe L, XL
Neu
Sonderpreis
FRAME
FORK
SHOCK
RIMS
HUB REAR
HUB FRONT
SPOKES
TIRES
DERAILLEUR REAR
DERAILLEUR FRONT
SHIFT LEVER
CRANKSET
MOTOR
CHAIN
CASSETTE
BRAKES FRONT
BRAKES REAR
BRAKE LEVERS
HANDLEBAR
STEM
GRIPS
HEADSET
SEATPOST
SADDLE
Marin eMTB Saddle
PEDALS
Marin MTB Plastic
BATTERY
DISPLAY
SC-E7000 Display
SWITCH
EXTRAS
automatisch übersetzt
Marin Bikes Alpine Trail E1 E-Bike Mountain Shimano Steps 2022 Neu kaufen
3.799 €
Verkäufer Deusmagnus
5/5
basierend auf 1182 Bewertungen.
Use-Elitebikes
Gewerbliche/r Anbieter*in
Details & Spezifikationen : Marin Bikes Alpine Trail E1 E-Bike Mountain Shimano Steps 2022 Neu
Anzahl | 1 |
Hersteller | Marin Bikes |
Zustand | neu |
Land | Österreich |
Abholung | Ja |
Ort | Ebreichsdorf |
Rahmengröße | Other |
Dämpfer-Einbaumaße | Sonstige |
Laufradgröße | 29" |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 672 × |
Momentane Betrachter | 1 |
Veröffentlicht | 19. Nov 2023 08:15 |
Endet | 19. Nov 2024 08:15 |
