Formula Cura CNC Levers with sealed bearings
Fotos: Formula Cura CNC Levers with sealed bearings
Artikelbeschreibung: Formula Cura CNC Levers with sealed bearings
CNC machined and anodized levers for Formula Cura brakes, limited production made in Italy.
Now with ball bearings at all pivot points and a new barrel nut.
Zero play
Zero wear
Zero friction
Zero plastics
Better ergonomics: 5mm shorter reach, 1mm thinner for more comfort for small hands, slimmer profile at the "hook" for better clearance when pulling close to the bar, drilled for grip
Raw levers are normally in stock (natural aluminium silver color); in the photos you can see just some of the anodized colors to choose from (+15€. Contact me for availability and preorders) anodizing available in standard glossy and matte.
Also available in mirror polished finish (+15€)
Non-standard sizes also avaliable: 10mm shorter and 10mm longer.
Longer levers have +15% power and modulation, a great upgrade for the Cura 2.
Shorter levers have about 18% less travel (that is, less movement required) They can be useful for Cura 4 owners who want a quicker lever, with less modulation, by trading a bit of power.
In both cases it may be necessary to change the position of the clamps on the handlebar. This can be an opportunity to solve fitment issues.
The price is for a pair including shipping with registered international mail. Express shipping also available.
If you have any questions just ask!
Zero play
Zero wear
Zero friction
Zero plastics
automatisch übersetzt
Formula Cura CNC Levers with sealed bearings kaufen
84 €
Verkäufer RGTec
5/5
basierend auf 113 Bewertungen.
Details & Spezifikationen : Formula Cura CNC Levers with sealed bearings
Anzahl | 2 |
Hersteller | Formula |
Zustand | neu |
Land | Italien |
Abholung | Nein |
Angesehen | 2.387 × |
Momentane Betrachter | 1 |
Veröffentlicht | 21. Dez 2023 09:57 |
Endet | 21. Dez 2024 09:57 |
