Specialized Süecialized Stumpjumper Pro
Fotos: Specialized Süecialized Stumpjumper Pro
5.000 €
VHB
Artikelbeschreibung: Specialized Süecialized Stumpjumper Pro
Sehr gepflegtes Stumpjumper Gebraucht wie Neu 200 km gefahren neupreis 9900.- €
Größe S 3
DÄMPFER
FOX FLOAT DPS Factory, Rx Trail Tune, EVOL Air sleeve, Kashima Coat, 3-position adjustment w/ Open Mode Adjustment, 190x45mm
GABEL
FOX FLOAT 34 Factory, GRIP2 damper, Kashima Coating, 15x110mm, 44mm offset, 140mm of travel
VORBAU
Deity, 35.0mm
LENKER
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
LENKERGRIFFE
Deity, Knuckleduster, Black
SATTEL
Bridge, 155/143mm, Hollow Ti-rails
SATTELSTÜTZE
Bike Yoke, Revive Max, 34.9 (S1:120mm, S2/S3:150mm, S4-S6: 185mm)
BREMSE VORNE
SRAM G2 RSC, 4-piston caliper, hydraulic disc, 200mm
BREMSE HINTEN
SRAM G2 RSC, 4-piston caliper, hydraulic disc, 180mm
Antrieb
SCHALTWERK
SRAM X01 Eagle AXS
SCHALTHEBEL
SRAM Eagle AXS Rocker Paddle
KASSETTE
SRAM XG-1295 Eagle, 10-52t
KETTE
SRAX X01 Eagle, 12-speed
KURBELGARNITUR
SRAM X1 Carbon, DUB, S1:165mm, S2-S5: 170mm, S6: 175mm
KETTENBLÄTTER
Alloy, 30T
INNENLAGER
SRAM DUB, BSA 73mm, Threaded
Laufräder
FELGEN
Roval Traverse Carbon 29, hookless carbon, 30mm inner width, hand-built, 2Bliss Ready
VORDERRADNABE
DT Swiss 350, sealed cartridge bearings, 15x110mm spacing, 28h
HINTERRADNABE
DT Swiss 350, Star Ratchet, 36t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
SPEICHEN
DT Competition Race
VORDERREIFEN
Butcher, GRID casing, GRIPTON® T9 compound, 29x2.3"
HINTERREIFEN
Purgatory, GRID casing, GRIPTON® T7 compound, 29x2.3"
SCHLÄUCHE
Standard, Presta Valve
Größe S 3
DÄMPFER
GABEL
VORBAU
Deity, 35.0mm
LENKER
LENKERGRIFFE
SATTEL
SATTELSTÜTZE
BREMSE VORNE
BREMSE HINTEN
Antrieb
SCHALTWERK
SRAM X01 Eagle AXS
SCHALTHEBEL
KASSETTE
KETTE
KURBELGARNITUR
KETTENBLÄTTER
Alloy, 30T
INNENLAGER
Laufräder
FELGEN
VORDERRADNABE
HINTERRADNABE
SPEICHEN
DT Competition Race
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
automatisch übersetzt
Specialized Süecialized Stumpjumper Pro kaufen
5.000 €
VHB
Verkäufer xxxxel
5/5
basierend auf 5 Bewertungen.
Details & Spezifikationen : Specialized Süecialized Stumpjumper Pro
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | gebraucht, wie neu |
Land | Deutschland |
Abholung | Ja |
Ort | Eisenberg Pfalz |
Gewicht | 12,8 |
Rahmengröße | M |
Federweg vorn | 140 mm |
Federweg hinten | 140 mm |
Steuerrohr-Länge | 110 mm |
Dämpfer-Einbaumaße | 190 x 45 mm Metric |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 1x12 AXS |
Angesehen | 1.118 × |
Momentane Betrachter | 1 |
Veröffentlicht | 10. Jan 2024 16:15 |
Endet | 11. Feb 2025 10:26 |
