Cube Stereo Hybrid 160 HPC SLT 750Wh
Fotos: Cube Stereo Hybrid 160 HPC SLT 750Wh
8.499 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Cube Stereo Hybrid 160 HPC SLT 750Wh
[left]Packing everything Cube knows about enduro hybrid bikes into a powerful package with a bigger battery than before, the Stereo Hybrid 160 HPC SLT 750 is the ultimate choice for extended adventures.
With up to 85Nm of torque from Bosch's fourth-generation CX drive unit - backed up by a high-capacity 750Wh battery - and Sram's wireless AXS technology delivering precise, rapid shifts across the entire range of the 12-speed cassette, any trail will seem flatter.
Newmen Advanced carbon wheels are shod with Schwalbe Magic Mary and Big Betty SuperTrail 2.4in tyres and brought to a halt by Magura's four-piston, two-piece disc MT7 hydraulic brakes. And the Fox Transfer dropper post, Fox 38 Float Factory fork and Float X Factory shock will take on any trail challenge. It's ready. Are you?
The Stereo Hybrid 160 HPC 750's frame is designed to blend world-class trail-taming abilities with superb handling and more range than ever before. With the high-capacity 750Wh battery and fourth-generation Bosch drive unit housed entirely inside the down tube, it's as powerful as it is good to look at.
Hidden by a cover with shock protection, push-button access and a hidden lock, the battery is both secure and easy to access. Integrated cable routing removes cable holes from the head tube area for greater strength and a neater appearance.
The trunnion shock mount, oversize linkage bearings, Boost 148 rear end and 1.5in head tube all contribute to accurate tracking, even when it's all coming at you thick and fast. And sorted, race-inspired geometry gives you the advantage you need to show the trail exactly who's boss.
Key Features Of The Cube Stereo Hybrid 160 HPC SLT 750Wh Silver And Carbon[/left]
[left][/left]
[left]
What's Included[/left]
[left]
Manual, keys and charger included
Built, configured and tested by a Bosch approved technician
Full technical handover and ongoing support if required[/left]
[left][/left]
[left]
- Motor: Bosch Drive Unit Performance CX Generation 4 (85Nm) Smart System
- Display: Bosch Kiox 300
- Battery: Bosch PowerTube 750
- Frame: C:62 Monocoque Advanced Twin Mold Technology , Aluminium 6061 T6 Rear Triangle
- Wheels: Newmen Advanced SL A.30, 28/28 Spokes, 15x110mm/12x148mm, Tubeless Ready
- Fork: Fox 38 Float Factory FIT GRIP2, Tapered, 15x110mm, E-Bike Tune, 170mm
- Rear Derailleur: Sram XX1 Eagle AXS™, 12-Speed
- Crankset: e*thirteen Plus Crank, 165mm, 36T
- Brake System: Magura MT7, Hydr. Disc Brake
[left]
automatisch übersetzt
Cube Stereo Hybrid 160 HPC SLT 750Wh kaufen
8.499 €
www.leendersfietsen.nl
Gewerbliche/r Anbieter*in
Details & Spezifikationen : Cube Stereo Hybrid 160 HPC SLT 750Wh
Anzahl | 1 |
Hersteller | Cube |
Modell | Cube Stereo |
Zustand | neu |
Land | Niederlande |
Abholung | Ja |
Ort | Hengelo Ov |
Farbe | Silver/Carbon |
Rahmengröße | L |
Federweg vorn | 170 mm |
Federweg hinten | 160 mm |
Dämpfer-Einbaumaße | 205 x 65 mm Trunnion |
Laufradgröße | 27,5" / 650b |
Material | Carbon |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 632 × |
Momentane Betrachter | 1 |
Veröffentlicht | 30. Jan 2024 10:19 |
Endet | 30. Jan 2025 10:19 |
