RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
Fotos: RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
599 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
ROCKSHOX ZEB ULTIMATE
CHARGER 3
BUTTERCUPS
27.5"
170mm
offset 44mm
NEW
Detailed specification:
- Wheel size: 27.5"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Spring: DebonAir+ with ButterCup
- Damper: Charger 3 RC2 with ButterCup
- Adjustments:
- stiffness,
- progression,
- rebound,
- high speed compression,
- low compression damping
- Manufacturer's code: 00.4020.819.006
- Random unit serial nr: 31T23829602
- Axle: 15/110mm Boost
- Steerer: tapered (1 1/8" - 1.5"), uncut, 264mm long,
- Min. disc size: 200mm
- Max. disc size: 220mm
- Length from axle to crown (mm): 577
- Max. tire diameter (mm): 732
- Max. tire width (mm): 81
- Warranty: 1 month
- Grey color
- Brand new, not used, not installed on the bike, steering tube was not cut.
BOX version:
- original box,
- screw-on fender,
- 2 tokens (+1 inside),
- star nut,
- manual,
- sticker.
PayPal payment is possible.
CHARGER 3
BUTTERCUPS
27.5"
170mm
offset 44mm
NEW
- Wheel size: 27.5"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Adjustments:
- stiffness,
- progression,
- rebound,
- Warranty: 1 month
- Grey color
BOX version:
- original box,
- screw-on fender,
- star nut,
- manual,
- sticker.
automatisch übersetzt
RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX kaufen
599 €
Hard Bike
Gewerbliche/r Anbieter*in
Details & Spezifikationen : RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
Anzahl | 10 |
Hersteller | RockShox |
Modell | RockShox Zeb |
Zustand | neu |
Abholung | Ja |
Ort | Glogow |
Länge Gabelschaft | 264 mm |
Farbe | Schwarz |
Federweg | 170 mm |
Laufradgröße | 29" |
Nabenbreite vorn | 110 mm |
Achsdurchmesser Vorderrad | 15 mm |
Material | Aluminium |
Gabelschaft | Tapered |
Achstyp | Boost 110x15 mm Steckachse |
Federungstyp | Air Debonair |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 274 × |
Momentane Betrachter | 1 |
Veröffentlicht | 28. Mär 2024 21:46 |
Endet | 28. Mär 2025 21:46 |
