RockShox ZEB Ultimate 29" 170mm Charger 3 Offset 44mm Buttercups NEW
Fotos: RockShox ZEB Ultimate 29" 170mm Charger 3 Offset 44mm Buttercups NEW
699 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: RockShox ZEB Ultimate 29" 170mm Charger 3 Offset 44mm Buttercups NEW
ROCKSHOX ZEB ULTIMATE
CHARGER 3
BUTTERCUPS
29"
170mm
offset 44mm
NEW
Deatiled description:
- Wheel size: 29"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Spring: DebonAir+ with ButterCup
- Damper: Charger 3 RC2 with ButterCup
- Adjustments:
- stiffness,
- progression,
- rebound,
- high speed compression,
- low compression damping,
- Axle: 15/110mm Boost,
- Steerer: tapered (1 1/8" - 1.5"), uncut, 264mm long,
- Min. disc size: 200mm,
- Max. disc size: 220mm,
- Length from axle to crown (mm): 586,
- Max. tire diameter (mm): 770,
- Max. tire width (mm): 81,
- Crown width: 63mm,
- Warranty: 1 month,
- Color: glossy black,
- The exact specification decoded by the serial number can be found in the last photo,
- Random sample code: 07T31358946,
- Brand new, never used, not installed on the bike, steering tube was not cut.
Included:
- fork,
- Maxle axle with quick release,
- 3 tokens (1 pre-installed, 2 loose),
- 2 washers,
- manual,
- RockShox sticker.
The shock absorber is delivered in secure replacement packaging (oem version). New, unused product, was not disassembled from the bike.
Photos show sold forks.
PayPal payment is possible.
CHARGER 3
BUTTERCUPS
29"
170mm
offset 44mm
NEW
- Wheel size: 29"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Adjustments:
- stiffness,
- progression,
- rebound,
Included:
- fork,
- 2 washers,
- manual,
- RockShox sticker.
automatisch übersetzt
RockShox ZEB Ultimate 29" 170mm Charger 3 Offset 44mm Buttercups NEW kaufen
699 €
Hard Bike
Gewerbliche/r Anbieter*in
Details & Spezifikationen : RockShox ZEB Ultimate 29" 170mm Charger 3 Offset 44mm Buttercups NEW
Anzahl | 10 |
Hersteller | RockShox |
Modell | RockShox Zeb |
Zustand | neu |
Abholung | Ja |
Ort | Glogow |
Länge Gabelschaft | 264 mm |
Farbe | Schwarz |
Federweg | 170 mm |
Gabel-Offset | 44 mm |
Laufradgröße | 29" |
Nabenbreite vorn | 110 mm |
Achsdurchmesser Vorderrad | 15 mm |
Material | Aluminium |
Gabelschaft | Tapered |
Achstyp | Boost 110x15 mm |
Federungstyp | Air Debonair |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 499 × |
Momentane Betrachter | 1 |
Veröffentlicht | 7. Apr 2024 12:01 |
Endet | 7. Apr 2025 12:01 |
