Specialized Enduro S-Works M (2017) - Originalausstattung: Öhlins, Sram XX1
Fotos: Specialized Enduro S-Works M (2017) - Originalausstattung: Öhlins, Sram XX1
2.750 €
VHB
Artikelbeschreibung: Specialized Enduro S-Works M (2017) - Originalausstattung: Öhlins, Sram XX1
Reifen und Griffe sind neu, ansonsten ist das Bike komplett in Originalausstattung.
Bike wurde benutzt und hat dementsprechend Gebrauchsspuren, allerdings keinerlei funktionelle Beeinträchtigungen.
Service an Dämpfer und Gabel wurde diesen Winter durchgeführt.
Technische Spezifikationen
FRAME
FACT 11m, X-Wing layout, full carbon chassis and rear end, All-Mountain Geometry, SWAT™ Door integration, threaded BB, fully enclosed internal cable routing, ManFu link, oversized pivot bearings, 12x148mm dropouts, replaceable derailleur hanger, 165mm of travel
REAR SHOCK
Custom Öhlins STX, Single Tube design, Rx All-Mountain Tune, 3rd Chamber air spring technology, AUTOSAG, adjustable compression & rebound damping, 216x57mm
FORK
Öhlins RXF 36, 29/27.5+, Twin-Tube design, air spring w/ adjustable 3rd chamber, adjustable high and low speed compression, adjustable rebound, 15x110mm thru-axle, 51mm offset, 160mm travel
RIMS
Roval Traverse SL 29, hookless carbon, 30mm inner width, 24/28h, tubeless ready
FRONT HUB
Roval Traverse, sealed cartridge bearings, 15mm thru-axle, 110mm spacing, 24h
REAR HUB
Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
REAR DERAILLEUR
SRAM XX1 Eagle, 12-speed
SHIFT LEVERS
SRAM XX1 Eagle, 12-speed, trigger
CASSETTE
SRAM XG-1295, 12-speed, 10-50t
CRANKSET
SRAM XX1 Eagle, carbon, 24mm spindle, 52mm chainline, 30T
CHAIN
SRAM XX1 Eagle, black, 12-speed w/PowerLink
BOTTOM BRACKET
SRAM GXP XR, 73mm
STEM
Syntace MegaForce 2, 6-degree, 31.8mm bar clamp
HANDLEBARS
Specialized DH, FACT carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 31.8mm
SADDLE
Body Geometry Henge Expert, hollow titanium rails, 143mm
SEATPOST
Command Post IRcc, 12 position micro-height adjustable, alien head design, bottom mount cable routing, remote adjust SRL lever, 30.9mm, S: 100mm, M/L/XL: 125mm travel
REAR BRAKE
SRAM Guide RS carbon, hydraulic disc, organic pads, carbon lever, Guide S4 4-piston caliper, 180mm rotor
FRONT BRAKE
SRAM Guide RS carbon, hydraulic disc, organic pads, carbon lever, Guide S4 4-piston caliper, 200mm rotor
Probefahrt ist möglich und erwünscht!
Verkauf ohne Pedale.
Details und Ausstattung kann noch auf der Specialized Seite eingesehen werden. Google: "Specialized Enduro S-Works 2017"
Kein Versand, nur Abholung.
FRAME
REAR SHOCK
FORK
RIMS
FRONT HUB
REAR HUB
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE
CRANKSET
CHAIN
BOTTOM BRACKET
SRAM GXP XR, 73mm
STEM
HANDLEBARS
SADDLE
SEATPOST
REAR BRAKE
FRONT BRAKE
automatisch übersetzt
Specialized Enduro S-Works M (2017) - Originalausstattung: Öhlins, Sram XX1 kaufen
2.750 €
VHB
Details & Spezifikationen : Specialized Enduro S-Works M (2017) - Originalausstattung: Öhlins, Sram XX1
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Enduro |
Zustand | gebraucht |
Land | Deutschland |
Abholung | Ja |
Ort | Heidelberg |
Gewicht | 13,5 |
Farbe | Gelb/Rot |
Rahmengröße | M |
Federweg vorn | 160 mm |
Federweg hinten | 160 mm |
Dämpfer-Einbaumaße | 216 x 57 mm |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 12 |
Angesehen | 164 × |
Momentane Betrachter | 1 |
Veröffentlicht | 2. Mai 2024 19:44 |
Endet | 2. Mai 2025 19:44 |
