Specialized S-Works Stumpjumper S3 Specialized
Fotos: Specialized S-Works Stumpjumper S3 Specialized
4.999 €
Artikelbeschreibung: Specialized S-Works Stumpjumper S3 Specialized
Verkaufe S- Works Stumjumper 2021 Rahmengröße S3 (M), sehr gepflegt bzw. Neuwertig. Farbe: !Satin Redwood/Smoke!
Das Rad kann in Lahnstein bei VORANMELDUNG (Bitte kurze Nachricht schreiben!):
Laufrad Racingbikes
Bahnhofstraße 27
56112 Lahnstein
angesehen und Probe gefahren werden.
Versand möglich!
Privatverkauf!
Details siehe bitte:
/de/de/s-works-stumpjumper/p/175248?color=300727-175248
Technische Spezifikationen
Rahmenset
RAHMEN
FACT 11m carbon chassis and rear-end, carbon shock extension, asymmetrical design, 29 Trail Geometry, SWAT™ Door integration, flip chip Head Tube/Bottom Bracket adjustment, threaded BB, fully enclosed internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 130mm of travel
SWAT
SATTELSTÜTZKLEMME
Alloy, 38.6
Fahrwerk
DÄMPFER
FOX FLOAT DPS Factory, Rx Trail Tune, EVOL Air sleeve, Kashima Coat, 3-position adjustment w/ Open Mode Adjustment, 190x45mm
GABEL
FOX FLOAT 34 Factory, GRIP2 damper, Kashima Coating, 15x110mm, 44mm offset, 140mm of travel
Cockpit
SATTEL
Bridge, 155/143mm, Hollow Ti-rails
SATTELSTÜTZE
RockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
LENKER
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
VORBAU
Deity, 35.0mm
LENKERGRIFFE
Deity, Knuckleduster, Black
Bremsen
BREMSE VORNE
SRAM G2 ULTIMATE, 4-piston caliper, hydraulic disc, 200mm
BREMSE HINTEN
SRAM G2 ULTIMATE, 4-piston caliper, hydraulic disc, 180mm
Antrieb
SCHALTHEBEL
SRAM XX1 Eagle AXS
KASSETTE
SRAM XG-1299 Eagle, 10-52t
SCHALTWERK
SRAM XX1 Eagle AXS
KETTE
SRAM XX1, 12 speed
KURBELGARNITUR
SRAM XX1 Eagle, DUB, S1:165mm, S2-S5: 170mm, S6: 175mm
KETTENBLÄTTER
30T
INNENLAGER
SRAM DUB, BSA 73mm, Threaded
Laufräder
FELGEN
Roval Control 240, hookless carbon, 29mm inner width, hand-built, 2Bliss Ready
VORDERRADNABE
DT Swiss 240, sealed cartridge bearings, 15x110mm spacing, 28h
HINTERRADNABE
DT Swiss 240, Ratchet EXP, 36t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
SPEICHEN
DT Swiss Competition Race
VORDERREIFEN
Butcher, GRID casing, GRIPTON® compound, 29x2.3"
HINTERREIFEN
Purgatory, GRID Casing, GRIPTON® compound, 29x2.3"
SCHLÄUCHE
Standard, Presta valve
* Gewichte basieren auf der Produktion lackierter Rahmen, wie abgebildet. Tatsächliche Gewichte variieren je nach Farbgebung, Rahmengröße und Komponentenvariation. Spezifikationen können ohne Vorankündigung geändert werden.
Laufrad Racingbikes
Bahnhofstraße 27
56112 Lahnstein
Versand möglich!
Privatverkauf!
Rahmenset
RAHMEN
SWAT
SATTELSTÜTZKLEMME
Alloy, 38.6
Fahrwerk
DÄMPFER
GABEL
Cockpit
SATTEL
SATTELSTÜTZE
LENKER
VORBAU
Deity, 35.0mm
LENKERGRIFFE
Bremsen
BREMSE VORNE
BREMSE HINTEN
Antrieb
SCHALTHEBEL
SRAM XX1 Eagle AXS
KASSETTE
SCHALTWERK
SRAM XX1 Eagle AXS
KETTE
SRAM XX1, 12 speed
KURBELGARNITUR
KETTENBLÄTTER
30T
INNENLAGER
Laufräder
FELGEN
VORDERRADNABE
HINTERRADNABE
SPEICHEN
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
automatisch übersetzt
Specialized S-Works Stumpjumper S3 Specialized kaufen
4.999 €
Verkäufer Midhurst
5/5
basierend auf 1 Bewertungen.
Details & Spezifikationen : Specialized S-Works Stumpjumper S3 Specialized
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | gebraucht, wie neu |
Land | Deutschland |
Abholung | Ja |
Ort | Lahnstein |
Gewicht | 12 kg |
Farbe | Satin Redwood Smoke |
Rahmengröße | M |
Federweg vorn | 140 mm |
Federweg hinten | 130 mm |
Dämpfer-Einbaumaße | 190 x 40 mm Metric |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 12 |
Angesehen | 340 × |
Momentane Betrachter | 1 |
Veröffentlicht | 6. Mai 2024 17:17 |
Endet | 6. Mai 2025 17:17 |
