Giant TRANCE X Advanced Pro 1 SRAM X01 Bikeyoke Shimano XT
Item description: Giant TRANCE X Advanced Pro 1 SRAM X01 Bikeyoke Shimano XT
For sale is a mint Giant Trance X Advannced Cabon trail bike. The wheel is in top condition and was moved only 220 km in the Bremen area. The environment just does not do justice to the wheel.
The wheel was directly at the time of purchase in many points geupgraded, eg change to Fox Factory fork, Shimano 12-speed drive and 4-piston brakes, Bikeyoke Variostütze and the superlight SRAM XX1 Dub crank with Wolftooth chainring.
The original price was 6500, - euros. Giant has increased in price, the comparable model is now significantly more expensive. The frame is the same as the 2023 model.
The weight is incl. heavy saddle, relatively heavy tires and pedals only 13.7 kg. The frame has the lifetime Giant warranty and was additionally pasted in the stressed areas with 3M film.
The bike can be test ridden in Bremen or Minden. Shipping via "GO! Express & Logistics" forwarding in the original box is also possible.
The latest member of the Trance family has been equipped with more travel, so you enjoy full control even on the most demanding trails. The full carbon frame is designed for 135mm of rear travel and a 150mm suspension fork. The Maestro rear end has a dual adjustable "Advanced Forged" carbon bell crank with trunnion shock mount. Using Flip-Chip you can easily adjust the geometry to your riding style and terrain. For fine-tuning, you can choose between a steeper (66.2 degrees) or flatter (65.5 degrees) steering angle and a seat angle of 77.9 degrees or 77.2 degrees. Depending on the setting, this results in a bottom bracket drop of 30 mm or 40 mm. The bike rolls on 29-inch wheels, which provides additional smoothness in rough terrain.
Technical data:
Color: carbon smoke / metallic black
Model year: 2021
Frame: adv full carbon frame, Maestro rear triangle with geometry flip chip, carbon baffle, 135 mm travel, 12x148 mm
Fork: Fox 36 Performance Factory, GRIP2 damping, 150 mm travel, Boost 15x110 mm, Fox Mudhugger fender - contrary to the original equipment.
Shock: Fox Float DPX2 Performance, 185x55 mm, Trunnion mount
Rear derailleur: Shimano XT, 12-speed - contrary to the original equipment
Shift lever: Shimano XT, 12-speed - contrary to the original equipment
Cassette: Shimano XT, 12-speed, 10-51T - contrary to the original equipment
Chain: Shimano XT, 12-speed - contrary to the original equipment
Crankset: SRAM XX1 Eagle AXS DUB 1x12-speed crank Boost 170mm + Wolf Tooth chainring Boost 32T - contrary to original equipment
Bottom bracket: SRAM DUB Pressfit
Brake: Shiamno SLX (4-piston), 200/200 mm - contrary to the original equipment
Brake lever: Shiamno SLX - contrary to the original equipment
Rims: GIANT TRX 2 29 Carbon, Tubeless Ready, 30 mm inner width
Tires: Maxxis Minion DHF 29x2.5WT, 60 TPI, 3C MaxxTerra, EXO, Tubeless Ready / Maxxis Dissector 29x2.4WT, 60 TPI, 3C MaxxTerra, EXO, Tubeless Ready, tubeless delivery.
Handlebar: GIANT Contact SLR TR35 Carbon, 20 mm rise
Stem: GIANT Contact SL 35
Grips: Ergon GE1 - contrary to the original equipment
Saddle: GIANT Romero SL
Seatpost: BikeYoke REVIVE Variostütze 30.9 mm (185 mm) - contrary to the original equipment
Control lever Variostütze: Shimano
Extras: Tubeless Kit (fluid, valves, tire levers, valve core remover,)
Pedals: not included
Hubs: GIANT TRX 2 (Made by DT Swiss)
automatically translated
Buy Giant TRANCE X Advanced Pro 1 SRAM X01 Bikeyoke Shimano XT
€3,999
Response in: 1 h
Feedback: 166 (100%)
Trust Level: 1
Registered since:
Details & Specifications : Giant TRANCE X Advanced Pro 1 SRAM X01 Bikeyoke Shimano XT
Quantity 1
Brand Giant
Model Giant Trance X
Condition gebraucht, wie neu
Shipping Costs €39
Country Deutschland de
Pickup Yes
Location
Weight 13,7
Color schwarz
Frame Size XL
Travel Rear 150 mm
Travel Front 135 mm
Head Tube Tapered 1⅛″/1,5″
Rear Shock Configuration 185 x 55 mm Trunnion
Wheel Size 29"
Material Carbon
Speed/Gears 12
Views 2.135 ×
Current viewers 1
Published May 7, 2023 7:23 PM
Expires Feb 6, 2026 5:06 AM
