Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 12-speed, 175mm
Item description: Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 12-speed, 175mm
The SLX FC-M7120-B2 crank features an entirely new construction, using direct mount chainrings, special gear tooth profile for improved chain retention, and a 178mm Q-factor.
Features
Hollow-forged crank maximizes power transfer while limiting weight
Exchangeable single/double chainring
Crankset can be used as common component
Extra wide range with front double 36-26T
Benefits
Smoother driving even over bumpy terrain
Rigid and lightweight design boosts trail-riding enjoyment
Q-factor: 178 mm
Chainline: 51.8 mm
Rider tunable
Easier gearing than racing groupsets
Specifications
Weight: 700 g
Chain line: 51.8mm
Chain ring combination: 36-26T
Compatible BB type: Outboard
Compatible chain: HG 12-speed
Crank arm length: 175 mm
Gear arms: 4 arm
HOLLOWTECH II: Yes
Optional Chain Guard: Without chain/bash guard
P.C.D.: Direct Mount
Rear speeds: 12 (Front double)
Threaded BB Shell Width: 68 mm, 73 mm
Q-factor: 178mm
The crankset is brand new, in the original box.
I accept payment thru bank transfer and Revolut.
automatically translated
Buy Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 12-speed, 175mm
€100
Details & Specifications : Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 12-speed, 175mm
Quantity 1
Brand Shimano
Model Shimano SLX
Condition neu
Shipping Costs €15
Country Rumänien ro
Pickup no
Weight 700 g
Crank Mount Standard Hallowtech II
Accepted payment methods Bank transfer
Views 539 ×
Current viewers 1
Published Aug 7, 2024 5:37 PM
Expires Aug 7, 2025 5:37 PM
