Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 2x12-speed, 170mm
Photos: Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 2x12-speed, 170mm
Item description: Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 2x12-speed, 170mm
The SLX FC-M7120-B2 crank features an entirely new construction, using direct mount chainrings, special gear tooth profile for improved chain retention, and a 178mm Q-factor.
Features
Hollow-forged crank maximizes power transfer while limiting weight
Exchangeable single/double chainring
Crankset can be used as common component
Extra wide range with front double 36-26T
Benefits
Smoother driving even over bumpy terrain
Rigid and lightweight design boosts trail-riding enjoyment
Q-factor: 178 mm
Chainline: 51.8 mm
Rider tunable
Easier gearing than racing groupsets
Specifications
Weight: 691 g
Chain line: 51.8mm
Chain ring combination: 36-26T
Compatible BB type: Outboard
Compatible chain: HG 12-speed
Crank arm length: 170 mm
Gear arms: 4 arm
HOLLOWTECH II: Yes
Optional Chain Guard: Without chain/bash guard
P.C.D.: Direct Mount
Rear speeds: 12 (Front double)
Threaded BB Shell Width: 68 mm, 73 mm
Q-factor: 178mm
The crankset is brand new, in the original box.
I accept payment thru bank transfer and Revolut.
Features
Benefits
Q-factor: 178 mm
Chainline: 51.8 mm
Rider tunable
Specifications
Weight: 691 g
Chain line: 51.8mm
Gear arms: 4 arm
HOLLOWTECH II: Yes
Q-factor: 178mm
automatically translated
Buy Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 2x12-speed, 170mm
€100
Details & Specifications : Shimano SLX FC-M7120-B2 Crankset Boost 36/26T. 2x12-speed, 170mm
Quantity | 1 |
Brand | Shimano |
Model | Shimano SLX |
Condition | neu |
Shipping Costs | €15 |
Country |
Rumänien |
Pickup | no |
Weight | 691 g |
Crank Mount Standard | Hollowtech II |
Accepted payment methods | Bank transfer |
Views | 723 × |
Current viewers | 1 |
Published | Aug 7, 2024 5:46 PM |
Expires | Aug 7, 2025 5:46 PM |
