RockShox Revelation RC 160mm 27,5“ Boost, 46mm Offset
Photos: RockShox Revelation RC 160mm 27,5“ Boost, 46mm Offset
€210
o.n.o.
Item description: RockShox Revelation RC 160mm 27,5“ Boost, 46mm Offset
For sale a Rock Shox Revelation RC 160mm 27.5", Boost 15x110mm, 46mm offset.
Has not been ridden much, has been dusty for the last year when removed. I am therefore prepared to part with this fork on good terms.
It has minimal signs of use on the stanchions (see also pictures), the lower tubes are not affected. Function is flawless. Decals have been removed.
Last service at the end of 2023, after that it was still in use for 2-3 rides.
Steerer tube: shortened to approx. 194mm
Info from the manufacturer:
- Suspension travel: 160mm
- Offset: 46mm
- Steerer tube: 1.5" tapered aluminum
- Settings: external rebound, low speed comp, Motion Control damping
- Suspension: Debon Air
- Max. Tire diameter: 732mm
- Max. tire width: 81mm
- Max. rotor size: 220mm
- min rotor size: 180mm
- Crown material: forged, hollow aluminum
- Material dip tubes: Magnesium
- Axle to crown: 552mm
- Material stanchions: 35mm straight wall aluminum
Invoice is available, purchased mid-September 2021.
Can also be inspected and/or picked up in the Munich area.
If you have any questions, just let me know ;)
- Offset: 46mm
automatically translated
Buy RockShox Revelation RC 160mm 27,5“ Boost, 46mm Offset
€210
o.n.o.
Details & Specifications : RockShox Revelation RC 160mm 27,5“ Boost, 46mm Offset
Quantity | 1 |
Brand | RockShox |
Model | RockShox Revelation |
Condition | gebraucht |
Shipping Costs | €6.90 |
Country |
Deutschland |
Pickup | Yes |
Location | |
Fork Shaft Length | 194 mm |
Color | Schwarz |
Travel | 160 mm |
Fork Offset | 46 mm |
Wheel Size | 27,5" / 650b |
Hub Width (Front) | 110 mm |
Axle Diameter (Front) | 15 mm |
Material | Aluminium/Magnesium |
Steerer Type | Tapered |
Axle Type | Steckachse (15x110mm) |
Spring Type | DebonAir |
Accepted payment methods | PayPal, Bank transfer |
Views | 1.001 × |
Current viewers | 1 |
Published | Oct 5, 2024 4:00 PM |
Expires | Oct 5, 2025 4:00 PM |
