Formula Mod 185mm Trunion für alle Hub längen inkl. 3 Dämpfungsh. mit ÖL
Photos: Formula Mod 185mm Trunion für alle Hub längen inkl. 3 Dämpfungsh. mit ÖL
€420
Price incl. VAT and plus shipping costs.
The shipping costs can only be calculated when you are logged in. Log in
Item description: Formula Mod 185mm Trunion für alle Hub längen inkl. 3 Dämpfungsh. mit ÖL
The Formula MOD Coil damper was used for a prototype test project. It has not been ridden a lot, but has some marks and scratches as the shocks are installed and removed very often during this process. There are also scratches/scuff marks on the rear eyelet due to lack of clearance on the rear triangle. This is not a technical issue!
Delivery content:
1x Mod shock 185mm Trunnion
2+1x damping unit (this is the special feature of the Mod that you can easily replace them)
4x Travel Spacer 2,5/5/7,5mm Herewith the travel can be adjusted from 55mm to all common stroke lengths (2,5mm=52,5mm stroke, 5mm=50mm, 7,5mm =47,5mm, 7,5+2,5=45mm...)
1x Formula SL spring Titanium 450lb other hardnesses on request
1x damper oil (approx. 4/3 full for refilling when replacing the damper unit)
Thanks to the spacers and damper units, this damper can be adapted to almost all frames. But also has a wide adjustment range in installed M Tune of the damping without conversion.
Technical data:
Installation length: 185mm Trunnion
Stroke: Adjustable with spacer from 55mm -45mm
Rear hardware can be supplied on request, please contact us and let us know the required dimensions.
The shock is used, comes with invoice and limited 1 year warranty.
For questions: info (at) Truebc (dot) de
Delivery content:
Technical data:
automatically translated
Pflichtangaben nach GPSR
Further information may be contained in the product images.
Buy Formula Mod 185mm Trunion für alle Hub längen inkl. 3 Dämpfungsh. mit ÖL
€420
Verkäufer Truebc
5/5
basierend auf 20 Bewertungen.
Details & Specifications : Formula Mod 185mm Trunion für alle Hub längen inkl. 3 Dämpfungsh. mit ÖL
Quantity | 1 |
Brand | Formula |
Condition | gebraucht |
Country |
Deutschland |
Pickup | no |
Weight | 780g |
Color | Schwarz/Silber |
Rear Shock Type | Stahlfeder |
Rear Shock Configuration | 185 x 55 mm Trunnion |
Material | Aluminium |
Accepted payment methods | Bank transfer |
Views | 791 × |
Current viewers | 1 |
Published | Oct 31, 2024 9:55 AM |
Expires | Oct 31, 2025 9:55 AM |
