Liteville 301 MK10 L 27,5"/26" *hochwertige Parts* *viele Ersatzteile/Zubehör
Photos: Liteville 301 MK10 L 27,5"/26" *hochwertige Parts* *viele Ersatzteile/Zubehör
€1,350
o.n.o.
Item description: Liteville 301 MK10 L 27,5"/26" *hochwertige Parts* *viele Ersatzteile/Zubehör
Selling my used Liteville 301 MK10 size L in black anodized.
I am now selling my faithful companion due to moving my hobby to another area. The bike has spent most of the last few years in the dry cellar.
I have photographed the signs of wear as best I can.
I bought the bike second-hand and then fitted it with other high-quality parts. Unfortunately, the fork is now leaking a bit due to its long service life (but I still have a set of seals which I will add). A shock service would probably also be necessary. I only replaced the tires this year and fitted them with tubeless.
Thanks to its special geometry with a slack head angle, scaled-size wheels (26/27.5") and top equipment, the Liteville 301 has its famous climbing characteristics and professional downhill/enduro race performance from the MK 10 onwards. No model BEFORE the MK10 can match this performance.
Here are the key data and components:
Frame: Aluminum. Size L, fits perfectly for people with a height of approx. 170 cm to 185 cm. (I used it at 178 cm and it fitted very well).
Rear suspension travel 140 mm (can be converted to 160 mm with the enclosed swingarms) and 130-160 mm at the front
Weight: approx. 12 kg to 13 kg (estimated)
Rims: Syntace W35
Hubs: Syntace HighTorque MX (rear Silencer Kit installed, still loud :D even louder sprocket also available)
Front tires: Tubeless Magic Mary as good as new (ridden twice) ; 27.5 x 2.40
Rear tire: Tubeless Schwalbe Nobby Nic as good as new (ridden twice) ; 26 x 2.40
Crank: SRAM XX1 Carbon with 32 tooth chainring
Gears: SRAM XX1 1x11 incl. Syntace rear derailleur guard
Trigger: SRAM XX1
Fork: Rock Shox Pike RCT3 Dual Position Air 130-160mm
Shock: Rock Shox Monarch Plus RC3 high volume 200mm*57mm
Seatpost: VECNUM Moveloc 170 with Bikejoke Triggy (more comfortable to use than the original, but the original is included)
Seat clamp: VECNUM tooloc 38mm
Brakes: Magura MT7 with HC3 single-finger levers and Shift-Mix clamps (probably also need bleeding)
Handlebars: Syntace Vector 318 7075 12°
Stem: Synace MegaForce 2 Length: 50mm
Chain guide: Syntace SCS II (also suitable for 2x)
Grips: Sqlab
I would like to keep the saddle and pedals. The bike is being sold without saddle and pedals as I would like to keep them.
I will also include the following components and spare parts:
- Liteville 160mm levers
- Syntace thru axle tool
- Syntace P6 seatpost carbon 34,9mm
- Spare derailleur hanger
- Spare derailleur hanger bolt
- Vecnum seatpost original lever
- 1x normal clamp for Magura MT7
- 1x brake pads Magura MT7
- Syntace MX louder sprocket
- Rock Shox gasket set
- various Liteville cable holders and screws
Shipping is not possible. Please pick up only.
Please no exchange offers and also no offers with installment payment.
Please contact me if you have any questions. I can also send more photos if required.
The sale takes place under exclusion of any liability for material defects.
Rims: Syntace W35
Trigger: SRAM XX1
Grips: Sqlab
automatically translated
Buy Liteville 301 MK10 L 27,5"/26" *hochwertige Parts* *viele Ersatzteile/Zubehör
€1,350
o.n.o.
Verkäufer macc2
5/5
basierend auf 56 Bewertungen.
Details & Specifications : Liteville 301 MK10 L 27,5"/26" *hochwertige Parts* *viele Ersatzteile/Zubehör
Quantity | 1 |
Brand | Liteville |
Model | Liteville 301 |
Condition | gebraucht |
Country |
Deutschland |
Pickup | Yes |
Location | |
Weight | 13 kg |
Color | Schwarz |
Frame Size | L |
Travel Rear | 160 mm |
Travel Front | 160 mm |
Rear Shock Configuration | 200 x 57 mm |
Wheel Size | 27,5" / 650b |
Material | Aluminium |
Speed/Gears | 11 |
Views | 363 × |
Current viewers | 1 |
Published | Feb 25, 2025 10:47 AM |
Expires | Feb 25, 2026 10:47 AM |
