Formula SELVA S Federgabel 27,5 Zoll 180 mm Boost defekt
Photos: Formula SELVA S Federgabel 27,5 Zoll 180 mm Boost defekt
€250
o.n.o.
Item description: Formula SELVA S Federgabel 27,5 Zoll 180 mm Boost defekt
Formula SELVA S suspension fork 27.5 inch 180 mm Boost defective
Selling a Formula Selva S. Unfortunately it has a large scratch on the left stanchion (see pictures). The scratch was tried to be repaired with the Sendhit Scratch Cover repair kit.
Suspension travel can be reduced internally to 170mm.
A blue CTS and a Neopos are fitted.
Stem tube length: 189mm (claw is hammered in)
- Suspension travel: 180mm
- Steerer tube: Aluminium (anodized)
- Crown: Aluminum (hollow forged)
- Stanchions: Aluminium 7075 (hard anodized)
- Dip tubes: Magnesium
- Rake (offset): 37mm
- installed CTS valve: RED TUNE
- Installation height (+/- 5 mm): 570 mm
- stanchion diameter: 35 mm
- Hub installation width: 15x110mm Boost
- max. tire clearance: 2.5 inch (27.5/29)
- Weight: 2090g (reweighed)
- Air suspension with positive air chamber (individually adjustable)
- Mechanical negative spring made of steel (Triple Coil Technology)
- Damping: Drop-in cartridge with Internal Floating Technology (IFT) - the closed system allows servicing without removing the fork
- Settings: Rebound via 21 clicks, compression per high speed and low speed via 12 clicks
- Lockout (on the fork crown)
Shipping within Germany included, insured with DHL.
automatically translated
Buy Formula SELVA S Federgabel 27,5 Zoll 180 mm Boost defekt
€250
o.n.o.
Verkäufer rio de la rage
5/5
basierend auf 516 Bewertungen.
Details & Specifications : Formula SELVA S Federgabel 27,5 Zoll 180 mm Boost defekt
Quantity | 1 |
Brand | Formula |
Condition | defekt |
Country |
Deutschland |
Pickup | Yes |
Location | |
Fork Shaft Length | 189 mm |
Weight | 2090 |
Color | Schwarz |
Travel | 180 mm |
Einbauhöhe | 570 |
Fork Offset | 37 mm |
Reifenfreiheit | 2,5 |
Brake Mount (Front) | Post Mount 160 |
Wheel Size | 27,5" / 650b |
Hub Width (Front) | 110 mm |
Axle Diameter (Front) | 15 mm |
Material | Aluminium/Magnesium |
Steerer Type | Tapered |
Axle Type | Steckachse (15x110mm) Boost |
Spring Type | Luftfeder |
Views | 550 × |
Current viewers | 1 |
Published | May 4, 2025 1:43 PM |
Expires | May 4, 2026 1:43 PM |
