E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Item description: E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Biete diese wenig genutzte (Max 50km) 11-Fach Kassette an.
neupreis bei bike-components ist aktuell bei 183,99 EUR
/en/e-thirteen/TRS-Plus-11-speed-Cassette-p72637/
[center]The TRS Plus 11-speed cassette by e*thirteen is stable and also fits your e-bike[/center]
The TRS Plus 11-speed cassette by e*thirteen is extremely durable and thus also suitable for use on e-bikes. Unlike the previous model, the cassette consists of more steel and fewer aluminium sprockets, which makes it more durable. TRS Plus cassettes have always offered more range, more value and less weight than the competition.
Guidelines for Replacing E-bike Components:
Before you replace components on your e-bike, please read through the guidelines for component replacement for CE-marked e-bikes/pedelecs with pedal assistance.
Specifications:
Application:
Cross Country, Trail, All Mountain, Enduro, E-Bike
Gearing:
11-speed
Gradation:
9-46
Sprocket Material:
steel (sprockets 1 to 10), aluminium (sprocket 11)
Freehub Compatibility:
SRAM XD
Note:
To use the TRS Plus cassette on Hope hubs you need a shim. Not compatible with Shimano drivetrains.
Technical Information:
Series:
TRS Plus
Spider:
2 (1 x steel, 1 x aluminium)
Features:
  • 511% range
  • 2-part design allows aluminium and steel cluster to be exchanged separately
  • faster shifting
  • improved durability
  • new installation system eliminates the need for proprietary tools, only 3 mm hex wrench required
  • compatible with SRAM systems
Models:
9-46:
  • Gradation: 9-10-12-14-17-20-24-28-33-39-46 T
  • Manufacturer Number: FW2TPA-101
Contents:
  • 1 x e*thirteen TRS Plus 11-speed cassette
  • 1 x bushing
  • 1 x 3 mm set screw
  • 1 x 3 mm pinch bolt
  • 1 x grease
  • 1 x decal
Weight:
  • black/9-46: 390 g
Manufacturer:
e*thirteen
1120 Harold St
Alameda
CA 94501
USA
Buy E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
€125
Details & Specifications : E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Quantity 1
Brand E*Thirteen
Condition gebraucht, wie neu
Shipping Costs €7
Country Deutschland de
Pickup Yes
Location
Weight 390
Color Schwarz/Silber
Speed/Gears 11-fach
Speed/Gears 11
Views 314 ×
Current viewers 1
Published May 4, 2025 5:57 PM
Expires May 4, 2026 5:57 PM
