Specialized Diverge custom painted "Grind for good"
Fotos: Specialized Diverge custom painted "Grind for good"
4.500 €
VHB
Artikelbeschreibung: Specialized Diverge custom painted "Grind for good"
GRIND FOR GOOD CHARITY
This is a one-off bike, a bike that is made to impress; with its look and its capability on the ride. With speed, control, and confidence on any terrain, the Specialized Diverge is the most capable gravel bike ever made. Switching from Midwest gravel at Mach 5 to rutted single track with ease, nothing helps you escape faster than Diverge.
The bike exists in Size 56. Shipping worldwide at the expense of the buyer, only when prepaid.
FUELING A CAUSE AND YOUR CAFFEINE CRAVINGS
Whether you're grinding up a grueling climb or your favorite coffee beans to pull the perfect espresso shot, the collaboration between two industry leaders, Specialized and La Marzocco, was destined to brew something extraordinary. Brace yourselves for a unique fundraising opportunity where you can bid on a one-of-a-kind custom-painted Soil Searching La Marzocco Linea Mini and a matching Specialized Diverge, bringing your barista and gravel bike dreams to life.
The Gehrig Twins and Soil Searching have joined forces to fulfill your two-wheeled and caffeinated fantasies and support two incredible causes. First is the Hands for Songwa Coffee Farming project in Tanzania, a coffee farming initiative that aims to empower its members with coffee knowledge and uplift the local community's livelihoods by shining a light on the intricacies of the coffee value chain.
The second charity we're supporting is the NGO Outride, dedicated to improving the lives of youth through cycling. Because bicycles have the power to transform lives far beyond winning races. With this fundraiser, we're seizing the opportunity to make the daily grind a little easier for underprivileged communities.
Technical Specifications
FRAME
Specialized Diverge FACT 9r carbon, SWATTM Door integration, Future Shock suspension, threaded BB, internal routing, 12x142mm thru-axle, flat-mount disc
FORK
Future Shock 2.0 w/ Damper, Smooth Boot, FACT carbon, 12x100mm thru-axle, flat- mount
Cockpit
HANDLEBAR
Specialized Adventure Gear Hover, 103mm drop x 70mm reach x 12o flare FOREQUARTERS
Future Stem, Pro
HANDLEBAR TAPE
Supacaz Super Sticky Kush
SADDLE
Body Geometry Power Expert
SADDLE POST
Roval Terra Carbon Seat Post, 20mm offset
BRAKE FRONT
SRAM Rival eTAP AXS, hydraulic disc
REAR BRAKE
SHIFT LEVER
SRAM ED RIV ETAP AXS D1 SJD REAR/RT F20
SHIFTERS
SRAM GX Eagle AXS, w/ battery cover
CASSETTE
SRAM NX Eagle, 12-speed, 11-50t
CRANKSET
SRAM Rival 1 Wide
CHAIN BLADES
40T
INNER BEARINGS
SRAM DUB BSA 68
CHAIN
SRAM GX Eagle, 12-speed
Wheels and tires
FRONT WHEEL
Roval Terra C, 25mm inner width carbon rim, 32mm depth, NEW DT 370 hub, 24h, DT Swiss Comp Race spokes
REAR WHEEL
Roval Terra C, 25mm inner width carbon rim, 32mm depth, NEW DT 370 Star Ratchet hub, 24h, DT Swiss Comp Race spokes
FRONT TIRES
PATHFINDER PRO 2BR, TAN SIDEWALL, 700x42
REAR TIRES
FRAME
FORK
Cockpit
HANDLEBAR
Future Stem, Pro
HANDLEBAR TAPE
SADDLE
SADDLE POST
BRAKE FRONT
REAR BRAKE
SHIFT LEVER
SHIFTERS
CASSETTE
CRANKSET
SRAM Rival 1 Wide
CHAIN BLADES
40T
INNER BEARINGS
SRAM DUB BSA 68
CHAIN
Wheels and tires
FRONT WHEEL
REAR WHEEL
FRONT TIRES
REAR TIRES
automatisch übersetzt
Specialized Diverge custom painted "Grind for good" kaufen
4.500 €
VHB
Verkäufer Funtauna
5/5
basierend auf 38 Bewertungen.
Details & Spezifikationen : Specialized Diverge custom painted "Grind for good"
Momentane Betrachter | 2 |
Veröffentlicht | 21. Aug 2023 18:33 |
Endet | 21. Aug 2024 18:33 |
Angesehen | 2.760 × |
Anzahl | 1 |
Hersteller | Specialized |
Händler | Nein |
Zustand | neu |
Versandkosten | 100 € |
Abholung | Ja |
Ort | Flims |
Farbe | Rot/Beige |
Rahmengröße | 56 cm |
Material | Carbon |
