Hope Tech 3 V4 Duo, Bremsenset, Neu
419,99 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Hope Tech 3 V4 Duo, Bremsenset, Neu
Neuware inkl. Rechnung
Description
The master cylinder is combined with either our X2, E4 or V4 calipers will suit any riding for XC to Enduro/All mountain to DH.
The design is derived from the proven Tech 3 master cylinder and with the finger reach and bite point adjustments on each lever, you can be sure the levers will feel comfortable and suit your riding style. The Tech 3 Duo Master differs from our Uno system as there is a total independency between the front and rear calipers.
Two V4 calipers
2 independent circuits for safe operation
Tech 3 lever offers genuine bite point and reach adjustment without tools
V4 caliper uses 2x16mm and 2x18mm phenolic pistons to give more usable power
Uses post mount, 9.74 caliper with adapters to suit all mount options
CNC machined from 2014 T6 aluminium alloy
Top entry pad fitting
Shimano I-Spec A shifters can be fitted directly to lever body
Separate direct mounts also available for Shimano I Spec 2, I-Spec EV & Sram shifters
Anodized for durability
Compatible with a wide range of rotors from 160mm to 220mm.
Pflichtangaben nach GPSR
Weitere Angaben sind eventuell in den Produktbildern enthalten.
Hope Tech 3 V4 Duo, Bremsenset, Neu kaufen
419,99 €
sm-bikes de Gewerbliche/r Anbieter*in
Antwort in: 4 h
Bewertungen: 951 (100%)
Vertrauen: 20
Details & Spezifikationen : Hope Tech 3 V4 Duo, Bremsenset, Neu
Anzahl 1
Hersteller Hope Tech
Zustand neu
Land Deutschland de
Abholung Nein
Akzeptierte Bezahlmethoden PayPal, Überweisung
Angesehen 1.281 ×
Momentane Betrachter 1
Veröffentlicht 5. Jun 2024 21:17
Endet 5. Jun 2025 21:17
