Shimano DURA ACE Di2 SW-RS801-S Satellite Shifter Drops
Artikelbeschreibung: Shimano DURA ACE Di2 SW-RS801-S Satellite Shifter Drops
Shimano has been working for years to provide you with an advantage of seconds. The new 12-speed DURA-ACE R9200 is the fastest groupset ever and the pinnacle of SHIMANO technology and innovation. Speed was the key driver for the development of this new generation road groupset. That's why every component has been revised, refined and optimised to make you even faster - whether to leave the peloton behind you or to win the final sprint on the Champs-Élysées.
Winning or losing by millimeters can be the difference between a seamless shift and the split second it takes to reach for a gear. With satellite shifters, in the drops or on the tops, additional custom shift locations help you perfectly manage your effort.
Features - Shimano DURA ACE Di2 SW-RS801-S Satellite Shifter Drops
Compact satellite shifter creates multiple, custom shift points on the handlebar
Attaches directly to the handlebar
Short cable, for Remote sprinter switch
100mm cable length EW-SD300
Product features
Use: Road
Group: Dura Ace Di2 R9250 / Ultegra Di2 R8100
Model: SW-R801-S
Compatibility: STI levers: ST-R9250, ST-R9270, ST-R8150, ST-R8170
Type: Shifting Switch
Position: On road bar
Handlebar mounting: left / right
Compatible electric wire: EW-SD300
E-tube Project: Yes
E-tube port (pcs): 0
E-tube connector (pcs): each 1
The delivery includes both Satellite Shifter Drops, they come as a set.
The shifters are delivered like in the photos, w/o original box.
Shimano DURA ACE Di2 SW-RS801-S Satellite Shifter Drops kaufen
65 €
Details & Spezifikationen : Shimano DURA ACE Di2 SW-RS801-S Satellite Shifter Drops
Anzahl 1
Hersteller Shimano
Modell Shimano Dura Ace
Zustand neu
Versandkosten 10 €
Land Rumänien ro
Abholung Nein
Gänge hinten 12-fach
Akzeptierte Bezahlmethoden Überweisung
Angesehen 1.278 ×
Momentane Betrachter 1
Veröffentlicht 30. Jul 2024 17:44
Endet 30. Jul 2025 17:44
