Specialized STUMPJUMPER 15 OHLINS COIL 2025
Fotos: Specialized STUMPJUMPER 15 OHLINS COIL 2025
6.900 €
Artikelbeschreibung: Specialized STUMPJUMPER 15 OHLINS COIL 2025
Selling a new Stumpjumper 15 Coil in size S4.
New and unridden with original components listed below.
With warranty and invoice
For more info message me!
FRAME
FACT 11m carbon chassis and rear-end, Trail Geometry, SWAT™ Door integration, head tube angle adjustment, threaded BB, internal brake and dropper cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, SRAM UDH compatible, 145mm of travel
FORK
Öhlins RXF38 M.2 29, TTX Twin Tube Damping, external low speed rebound adjust, external high and low speed compression adjustment, 15x110mm, 44mm offset, 160mm of travel
SHOCK ABSORBER
Öhlins TTX 22 M Coil, Ride Dynamics trail tune, external rebound adjust, external high and low speed compression adjustment, 210x55, S2: 434lbs, S3: 480lbs, S4: 525lbs, S5: 571lbs, S6: 605lbs
BRAKES
TRP DH-R EVO, 4-piston caliper, hydraulic disc, 220/203mm
CHAIN
SRAM GX Eagle Transmission Flattop Chain
CASSETTE
SRAM GX Eagle Transmission Cassette, 12spd, 10-52t
DRIVE BEARING
SRAM DUB, BSA 73mm Wide, Threaded
GEAR LEVER
SRAM AXS POD Controller
CRANKCASE
SRAM GX Eagle Crankset, 32T ring, 55mm Chainline, S2-S3: 165mm, S4-S6: 170mm
REAR GEARBOX
SRAM GX Eagle Transmission Derailleur
RINGS
Roval Traverse, hookless alloy, 30mm inner width, tubeless ready, St: 29, Z: 27.5
FRONT HUB
DT Swiss 370, 15x110mm, 28h
REAR HUB
DT Swiss 370, 12x148mm, 32h
COAT FRONT
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
COAT IN THE BACK
Eliminator, GRID GRAVITY casing, GRIPTON® T9/T7 compound, 2Bliss Ready, 27.5x2.3"
SEAT
Bridge Comp, Hollow Cr-mo rails, S1-S2: 155mm, S3-S6: 143mm
STEERING SUPPORT
Deity, 35mm clamp, 35mm length
THE FLU
Diety, Supracush, Black
THE STEERING WHEEL
Deity, Racepoint, 5-degree upsweep, 9-degree backsweep, 810 width, S2: 25mm rise: S3-S6: 38mm rise
SEAT SUPPORT
PNW Loam Dropper, tool-less travel adjust, Range lever, 34.9, S2: 150mm, S3: 170mm, S4-S6: 200mm
SWAT
SWAT 4.0 internal downtube storage
WEIGHT
15.3 kg (S4)
FRAME
FORK
SHOCK ABSORBER
BRAKES
CHAIN
CASSETTE
DRIVE BEARING
GEAR LEVER
CRANKCASE
REAR GEARBOX
RINGS
FRONT HUB
REAR HUB
COAT FRONT
COAT IN THE BACK
SEAT
STEERING SUPPORT
THE FLU
THE STEERING WHEEL
SEAT SUPPORT
SWAT
WEIGHT
15.3 kg (S4)
automatisch übersetzt
Specialized STUMPJUMPER 15 OHLINS COIL 2025 kaufen
6.900 €
Details & Spezifikationen : Specialized STUMPJUMPER 15 OHLINS COIL 2025
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | neu |
Land | Slowenien |
Abholung | Nein |
Rahmengröße | L |
Dämpfer-Einbaumaße | 190 x 40 mm Metric |
Laufradgröße | 26" |
Angesehen | 690 × |
Momentane Betrachter | 1 |
Veröffentlicht | 12. Nov 2024 22:14 |
Endet | 12. Nov 2025 22:14 |
