RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
Photos: RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
€599
Price incl. VAT and plus shipping costs.
The shipping costs can only be calculated when you are logged in. Log in
Item description: RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
ROCKSHOX ZEB ULTIMATE
CHARGER 3
BUTTERCUPS
27.5"
170mm
offset 44mm
NEW
Detailed specification:
- Wheel size: 27.5"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Spring: DebonAir+ with ButterCup
- Damper: Charger 3 RC2 with ButterCup
- Adjustments:
- stiffness,
- progression,
- rebound,
- high speed compression,
- low compression damping
- Manufacturer's code: 00.4020.819.006
- Random unit serial nr: 31T23829602
- Axle: 15/110mm Boost
- Steerer: tapered (1 1/8" - 1.5"), uncut, 264mm long,
- Min. disc size: 200mm
- Max. disc size: 220mm
- Length from axle to crown (mm): 577
- Max. tire diameter (mm): 732
- Max. tire width (mm): 81
- Warranty: 1 month
- Grey color
- Brand new, not used, not installed on the bike, steering tube was not cut.
BOX version:
- original box,
- screw-on fender,
- 2 tokens (+1 inside),
- star nut,
- manual,
- sticker.
PayPal payment is possible.
CHARGER 3
BUTTERCUPS
27.5"
170mm
offset 44mm
NEW
- Wheel size: 27.5"
- Stroke: 170mm
- Offset: 44mm
- Model: Ultimate
- Adjustments:
- stiffness,
- progression,
- rebound,
- Warranty: 1 month
- Grey color
BOX version:
- original box,
- screw-on fender,
- star nut,
- manual,
- sticker.
automatically translated
Buy RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
€599
Hard Bike
Commercial Seller
Details & Specifications : RockShox Zeb Ultimate 27,5" 170mm Charger 3 Offset 44mm ButterCups BOX
Quantity | 10 |
Brand | RockShox |
Model | RockShox Zeb |
Condition | neu |
Pickup | Yes |
Location | Glogow |
Fork Shaft Length | 264 mm |
Color | Schwarz |
Travel | 170 mm |
Wheel Size | 29" |
Hub Width (Front) | 110 mm |
Axle Diameter (Front) | 15 mm |
Material | Aluminium |
Steerer Type | Tapered |
Axle Type | Boost 110x15 mm Steckachse |
Spring Type | Air Debonair |
Accepted payment methods | PayPal, Bank transfer |
Views | 272 × |
Current viewers | 1 |
Published | Mar 28, 2024 9:46 PM |
Expires | Mar 28, 2025 9:46 PM |
