SRAM Force 1 Type 3.0 11-speed Rear Derailleur Long Cage
Photos: SRAM Force 1 Type 3.0 11-speed Rear Derailleur Long Cage
Item description: SRAM Force 1 Type 3.0 11-speed Rear Derailleur Long Cage
Specifications:
Series: SRAM Force 1
Application: Road
Gearing: 11-speed
Attachment: standard
Capacity: 11-32 to 10-42 tooth (long)
Compatibility: SRAM Road 11-speed
Technical Information:
Derailleur Pulleys: 12 teeth
Material: aluminium
Other Materials: steel
Features:
fast and accurate gear changes
special derailleur pulleys support the lateral chain movement
controlled chain tension due to the Roller Bearing Clutch™
with Cage Lock™ function for quick wheel changes and chain assembly
special design prevents chain slapping and ghost shifting
Model Index:
grey / long:
cage length: long
capacity: 11-32 to 10-42 teeth
Manufacturer Number: 00.7518.112.002
Contents:
1 x SRAM Force 1 Type 3.0 rear derailleur
The derailleur is brand new, in the original box. The box has some cosmetic damage from storage.
I accept payment thru bank transfer and Revolut.
Application: Road
Gearing: 11-speed
Material: aluminium
Features:
Model Index:
grey / long:
cage length: long
Contents:
automatically translated
Buy SRAM Force 1 Type 3.0 11-speed Rear Derailleur Long Cage
€150
Details & Specifications : SRAM Force 1 Type 3.0 11-speed Rear Derailleur Long Cage
Quantity | 1 |
Brand | SRAM |
Model | SRAM Force |
Condition | neu |
Shipping Costs | €10 |
Country | Rumänien |
Pickup | no |
Color | Black |
Speed/Gears | 11-fach |
Accepted payment methods | Bank transfer |
Views | 188 × |
Current viewers | 1 |
Published | Aug 7, 2024 5:55 PM |
Expires | Aug 7, 2025 5:55 PM |
