Niner Bikes RLT9 R7000 Gravel Cross Bike (FORGE GREY/ORANGE/TEAL)
2.699,00 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
02.11.2018 14:55
Endet
02.11.2019 14:55
Angesehen
487 ×
Anzahl
Hersteller
Niner Bikes
Zustand
neu
Abholung
Ja
Burbach
Farbe
gey/teal
Rahmengröße
53 cm
Material
Aluminium/Carbon
Händler
Ja
Land
Deutschland de
Diese Version wird immer frisch aufgebaut, Details siehe unten
Shimano R7000 2x11 Gruppe mit FlatMount (BR-R7020)
Änderungen sind:
- Laufräder mit NoTubes Grail Felge
- PraxisWorks Alba Kurbel 32/48 und PraxisWorks Innenlager
- ControlTech Komponenten (Vorbau/Lwnker/Sattelstütze)
- Fabric Sattel
Build details
- Niner's first All-Road Mountain Bike rules the domain between pavement and singletrack
- Custom 15mm gravel-tuned Niner carbon fork with rack mid mounts, shares DNA and safety testing standards with our legendary MTB version
- Fork mounts: 45lbs weight limit
- Rear rack: 55lbs weight limit
- Fire road geometry - slightly longer CS, lower BB and slacker HT angle
- Low profile disc brake post mount
- PF 30 BB shell is geared or singlespeed compatible with the new Niner BioCentric 30
- Hydroformed Aluminum alloy frame is light, efficient and beautiful
- 142x12 rear spacing
Technical specification and geometry
- 68 mm PF30 BB Shell (adaptors required for BSA Type BBS)
- Compatible with Biocentric 30 for single speed use
- Internal shifter routing ports are ready for Di2 and septets battery routing
- Front fender and rear rack/fender mounts
- 27.2 seat post, 400 MM Length recomended
- 31.8 Seat collar
- 1.125? X 1.5" Tapered integrated (Campy style) head tube, headset included, Cane creek description: IS42/28.6 | IS52/40
- Post Mount Disc Brake only
- 160 mm mx rotor size
- All sizes have 2 inner triangle bottle mounts
- Can fit up to a 1.75 tire (tire sizes may vary by brand, some tires may not fit)
- Compatible with standard 2X and 3X systems
FRAME RLT 9 - FORGE GREY/ORANGE/TEAL
FORK NINER FULL CARBON RDO FORK W/RACK MOUNTS, 15MM x 100MM THRU AXLE (M15x1.5Px125L)
FRONT WHEEL Powerway CenterLock CL 100X15MM FRONT
REAR WHEEL Powerway CenterLock CL 142X12MM REAR
FRONT TIRE SCHWALBE G-ONE EVO SS, FOLDING, 700 X 38
REAR TIRE SCHWALBE G-ONE EVO SS, FOLDING, 700 X 38
TUBESSEALANT STANS NO TUBES SEALANT (2 X 2oz BOTTLES)
BRAKES SHIMANO 105 R7070 HYDRAULIC
BRAKE LEVERSSHIMANO 105 R7020
BRAKE ROTORS SHIMANO RT70 160/160MM CL ROTORS
FRONT SHIFTER SHIMANO 105 R7020 11SP
REAR SHIFTER SHIMANO 105 R7020
FRONT DERAILLEUR SHIMANO 105 R7000 GS 11SP
REAR DERAILLEUR SHIMANO 105 R7000
CASSETTE SHIMANO 105 R7000 11SP 11-32T
CHAIN SHIMANO HG 601 11SP
CRANK SET PraxisWorks Alba M30 32/48 oder 34/50
BOTTOM BRACKET PraxisWorks M30
SADDLE Fabric Sport
SEAT POST ControlTech
HANDLEBAR ControlTech
STEM ControlTech
HEAD SET NINER INTEGRATED SHIS DESCRIPTION IS42/28.6|IS52/40
Avatar
Shop
Verkäufer:
Move-Cycles
de
Bewertungen:
4, 100,0 % positiv
Verkäufer nilsonwheels Verkäufer nilsonwheels
5/5 basierend auf 4 Bewertungen.
Vertrauensstufe: 0
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
