Felt VR Advanced Ultegra Di2 Carbon Rennrad Disc 2020 Neu
3.749,00 € VHB
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
15.09.2020 21:55
Endet
15.09.2021 21:55
Angesehen
138 ×
Anzahl
Hersteller
Felt
Zustand
neu
Abholung
Ja
Rahmengröße
Other
Material
Carbon
Händler
Ja
Land
Österreich at
Akzeptierte Bezahlmethoden
Banküberweisung
Rennrad
Carbon
Modell 2020
Neu
Verfügbare Größe: 47
Farbe Aqua
Frame Felt Variable Road UHC Advanced + TeXtreme carbon fiber, MMC with InsideOut construction, carbon fiber BB386 bottom bracket shell, 12 x 142mm with Syntace style thru axle, flat mount disc brake standard, replaceable rear derailleur hanger, internal mechan
Fork Felt Variable Road UHC Advanced + TeXtreme carbon fiber monocoque construction, size specific ControlTaper carbon fiber steerer tube, integrated crown race, crown and blades. Flat mount disc standard, 12 x 100mm thru axle
Headset FSA integrated sealed cartridge bearing with Felt VariableHeight Cone Spacers (20mm PC, 4.5mm aluminum), Felt top cap, 43 - 47cm: IS-21, 1.125", 51 - 61cm: No.42, 1.125 - 1.5"
Stem Devox SL, -7° rise, Ø31.8mm, 43 - 47cm: 80mm, 51cm: 90mm, 54 - 56cm: 100mm, 58cm: 110mm, 61cm: 120mm
Handlebar Devox Road Endurance, 65mm reach, 125mm drop, Ø31.8mm, 43-47cm: 380mm, 51cm: 400mm, 54 - 56cm: 420mm, 58 - 61cm: 440mm
Grips Felt VelvetGel tape with 3M reflective base with reflective Felt Bubble-Tech F-Wing bar end plugs
Shifters Shimano Ultegra Di2 R8070 11-speed
Front Derailleur Shimano Ultegra R8050 Di2 braze-on
Rear Derailleur Shimano Ultegra R8050 Di2 11-speed long cage
Crankset Shimano Ultegra R8000, 50/34T, 43 - 47cm: 165mm, 51cm: 170mm, 54 - 56cm: 172.5mm, 58 - 61cm: 175mm
Bottom Bracket Token BB386 with 24mm bearings
Chain Shimano 11-speed
Freewheel / Cassette Shimano 11-speed, 11-34T
Brake Levers Shimano Ultegra R8070, hydraulic
Brake (Front) Shimano R8070 hydraulic disc, 160mm rotor
Brake (Rear) Shimano R8070 hydraulic disc, 140mm rotor
Saddle Prologo Dimension Space T4.0
Seat post Devox UHC Performance carbon fiber with microadjust head, 43 - 51cm: Ø27.2mm x 344mm length
Seat post clamp Felt single bolt, Ø30.6mm
Wheels Reynolds AR29 DB Custom carbon, tubeless ready, 21mm inner width, 29mm depth
Front Hub Reynolds Series 1, straight-pull design, 12 x 100mm thru axle, Center Lock
Rear Hub Reynolds Series 1, straight-pull design, 4 pawl, 24T ratchet, 11-speed, 12 x 142mm thru axle, Center Lock
Spokes Sapim Sprint double butted
Thru Axles Front: 12 x 100 x 123, thread: M12 x 1.5P x 16L, Maxle; Rear: 12 x 142 x 163 (163L + 7 head = 170 total), thread: M12 x 1.0P x 19L, Syntace
Tyre Vittoria Rubino Pro G+ folding, 700 x 28c
Accessories Carbon assembly paste, chain plate protector, tubeless valve stems, Di2 battery charger
Finish (Accent) Aquafresh / TeXtreme
UVP: 4699.-
Hier um 3749.-
Avatar
Shop
Bewertungen:
658 (98,2 %)
Verkäufer Deusmagnus Verkäufer Deusmagnus
5/5 basierend auf 658 Bewertungen.
Vertrauen: 5
Antwort in: 29 min
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
