Norco Aurum HSP C2 Carbon Downhill Fully 2020 29er 27,5 Neu
4.999,00 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Momentane Betrachter
Veröffentlicht
17.12.2020 22:30
Endet
17.12.2021 22:30
Angesehen
329 ×
Anzahl
Hersteller
Norco
Zustand
neu
Abholung
Ja
Rahmengröße
Other
Dämpfer-Einbaumaße
190 x 40 mm Metric
Laufradgröße
Sonstige
Material
Carbon
Händler
Ja
Land
Österreich at
Akzeptierte Bezahlmethoden
Banküberweisung
Mountainbike
Downhillbike
Carbonrahmen
Neu
Modell 2020
29er und 27,5 möglich
Verfügbare Größen:
27,5: S, M, XL
29er: M/L, XL
Frame High Single Pivot DH Frame 29 M/L, L/XL, 650B XS/S, S/M, M/L, L/XL
Fork Rockshox Boxxer Select, Charger 200mm travel, boost 20x110
Rear Shock Rockshox Super Deluxe Coil Spring Ultimate DH RC shock
Headset Cane Creek 40 series 1-1/8 IS42 sealed bearing
Headset Spacer 3x10mm / 1x5mm / 1 x 2.5mm
Grips Deity KnuckleDuster lock on grip
Handle Bar Deity Race Point 810mm, 35mm bar, 38mm rise (M/L, L/XL)
Stem Deity Intake Direct Mount 31.8mm stem
Seat Post Norco 6061 alloy double bolt head
Seat Post Clamp Built into frame (bolt comes with frame)
Saddle SDG Fly RL saddle
Front Brake Sram Code R 4 piston hydraulic disc w/200mm rotor
Rear Brake Sram Code R 4 piston hydraulic disc w/200mm rotor
Brake Levers Rear shifter clamp
Shifter Front
Shifter Rear Sram GX 1 7 speed trigger
Front Derailleur
Rear Derailleur Sram GX DH 7sp mid cage RD
Cassette Sram CS PG720 DH 11-25T
Chain Sram PC 1110 11 speed chain
Crankset Truvativ Descendant DH DUB 165mm w/34T
Bottom Bracket Sram Pressfit DUB MTB 104.5mm
Chain Tensioner e*thirteen LG 1+ guide, alloy backplate w/lower guard
Pedals 0
Front Hub Novatech sealed bearing 20x110mm Boost front
Front Hub Skewer 0
Rear Hub DT 370 148x12 boost, Shimano/Sram cassette
Rear Hub Skewer Syntace X-12 axle 148L x 171 L
Spokes/Nipples DT Competition Double butted Stainless Steel - Black
Rims e*thirteen | LG1 DH Rim
Front Tire Maxxis Assegai 2.50 3C/MaxxGrip/DH/TR
Rear Tire Maxxis Assegai 2.50 3C/MaxxGrip/DH/TR
Preis 4999.-
Avatar
Shop
Bewertungen:
740 (98,5 %)
Verkäufer Deusmagnus Verkäufer Deusmagnus
5/5 basierend auf 740 Bewertungen.
Vertrauen: 5
Antwort in: 29 min
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
