Liteville 301 CE Pro MK1
6.200,00 € VHB
Momentane Betrachter
Veröffentlicht
30.12.2020 23:49
Endet
30.12.2021 23:49
Angesehen
996 ×
Anzahl
Hersteller
Liteville
Zustand
gebraucht, wie neu
Versandkosten
Abholung
Ja
Gewicht
23.5kg
Farbe
Black
Rahmengröße
L
Motor
Shimano
Akku-Kapazität
630 Wh
Federweg vorn
170 mm
Federweg hinten
160 mm
Steuerrohr
Tapered 1⅛″/1,5″
Steuerrohr-Länge
120 mm
Dämpfer-Einbaumaße
205 x 65 mm Trunnion
Laufradgröße
29"
Material
CARBON / Aluminium
Gänge
12
Händler
Nein
Land
Italien it
  • Frame - Liteville 301CE PRO Mk1, frame size L, carbon RAW main frame and aluminium rear triangle (black anodized), travel 160 mm
  • Headset - VarioSpin 0 °
  • Rear derailleur protection - Syntace RockGuard
  • Damper - RockShox Super Deluxe Coil Ultimate RCT with progressive Liteville Special spring (350-600lb your choice), damper installation length 205 mm - 65 mm stroke => 160 mm spring travel
  • Seat post - Eightpin NGS2 (fully integrated) / saddle height adjustable without having to shorten the seat tube
  • Suspension fork - Rock Shox Lyrik Ultimate RC2 BOOST, 42 mm offset, Solo Air 170 mm travel, thru-axle 15x110 mm, 29 "
  • Drive unit - Shimano STEPS 8000, 70 Nm (250 W), 3 power levels - Eco - Trail - Boost
  • Battery with 630 Wh capacity (removable from the frame)
  • Wheelset - Syntace W33i Straight Alu, internal width 33 mm, front 29 inches for 15x110 mm thru axle / rear 27.5 for 12 x 148 mm thru axle
  • Front tire - Schwalbe Magic Mary, 29x2.6 Apex Soft, Tubless
  • Rear tire - Schwalbe Eddy Current, 27.5x2.8 Apex Soft, tubeless
  • Switching group - Shimano XT (1x12-speed)
  • Crank - Shimano 160 mm
  • Chainring - Shimano 34 teeth
  • Cassette - Shimano XT (10-51)
  • Shifting unit - Shimano XT
  • Rear derailleur - Shimano XT
  • Chain - Shimano CN-8100, 12-speed
  • Brakes - Shimano, XT 8120, 4 pistons
  • Brake discs - Shimano SM-R76, Ø 203 / Ø 180 mm
  • Stem - Syntace Megaforce 2 including TwinFix, 30 mm length
  • Handlebar - Syntace Vector  Superlight  Carbon High 10, 12 ° 780mm
  • Spacer - Syntace MegaSpacer 2x 10mm spacer ring
  • Handlebar Grips - Syntace Screw-on Gripz Moto Ø 30 mm (Color Black)
  • Saddle - SQ-Lab 60X Erogowave active, width 14 cm
  • Syntace X-Fix 5 & 4 mm
  • Syntace Chain Tunnel (Carbon) guides the chain safely, protects the chain from dirt and thus significantly reduces chain wear
  • Syntace Skidplate (reinforced engine protection plate made of PC protects the engine from falling rocks and bumps)
  • no pedals
  • Helicopter tape on forks
  • Liteville charger 4A with adapter cable for charging from the battery when removed
  • Mileage approx. 250 km. Only used in Italy, Finale Ligure. Dry trails, almost zero rain or mud.
The bike has a max. System weight of 150 kg (bike + rider + equipment)
The rear structure is also suitable for the use of a 29 "wheel (=> DuoLink adjustment system).
2 years guarantee, in addition, 10 years through Syntace on material and manufacturing defects.
Frame length L - size recommendation: 178 - 190 cm. The bike is currently in Finale Ligure, Italy.
Shipping is at your cost and you arrange collection by the courier. Any questions please ask.
Avatar
Bewertungen:
4 (100,0 %)
Verkäufer MichaelCycle Verkäufer MichaelCycle
5/5 basierend auf 4 Bewertungen.
Vertrauen: 0
Antwort in: 1 h
