Yeti Cycles 2018 Sb6 Turq Small
Artikelbeschreibung: Yeti Cycles 2018 Sb6 Turq Small
For sale a brand new Yeti SB6 2018 frame
Raw/Grey
size Small
Yeti SB6 TURQ Frame Details:
TURQ Series Yeti bikes are made with the highest quality carbon fibre available and offer the perfect balance of stiffness and compliance. The result is a bike that feels smooth, solid and aggressive. The SB6 TURQ Series Frame weighs in at 6.05lb, and is burly enough for linebackers like Richie Rude.
Switch Infinity patented suspension system
High modulus carbon fibre main frame and swing arm
Collet axle system on pivots reduces bearing wear
Integrated ISCG-05 mounts
Custom downtube protector and chain guards
Internal cable routing
Yeti SB6 TURQ Frame Specs:
Travel 152MM
Frame Weight 6.05 LBS (2.75 KG)
Wheel Size 27.5”
Rear Shock Fox Factory DPX2
Rear Shock Sizing 8.5” X 2.5”
Bottom Bracket PF92
Tapered inset headtube (44mm/56mm)
Rear Wheel 148MM X 12MM (BOOST)
Seatpost 30.9MM
Yeti Cycles 2018 Sb6 Turq Small kaufen
1.900 €
Details & Spezifikationen : Yeti Cycles 2018 Sb6 Turq Small
Anzahl 1
Hersteller Yeti Cycles
Zustand neu
Versandkosten 100 €
Land Rumänien ro
Abholung Nein
Gewicht 2.75
Farbe Raw / Grey
Rahmengröße S
Federweg vorn 160 mm
Federweg hinten 153 mm
Steuerrohr Tapered 1⅛″/1,5″
Dämpfer-Einbaumaße 216 x 63 mm
Reifenfreiheit 2.4"
Bremssattelaufnahme hinten Post Mount
Laufradgröße 27,5" / 650b
Sattelstützendurchmesser 30,9 mm
Material Carbon
Angesehen 4.585 ×
Momentane Betrachter 1
Veröffentlicht 6. Feb 2021 10:38
Endet 18. Feb 2026 13:03
