Nukeproof Megawatt 297 Elite Bike (SLX) Größe: M
7.199,00 € VHB
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
» Artikel kaufen oder Frage stellen
Wir sind Ihr NUKEPROOF Händler für Deutschland, Österreich und Schweiz.   VERSAND MÖGLICH - DIESER ERFOLGT KOMPLETT MONTIERT UND EINGESTELLT.
BITTE MELDEN SIE SICH FÜR PREISVORSCHLÄGE DIREKT BEI UNS IM STORE - BIKE PERFORMANCE DRESDEN !
  • Frame: Nukeproof Megawatt 297 Alloy, 170mm Travel, custom triple butted hydro-formed tube set, internal Battery, Internal cable routing, Enduro Bearings, Boost 148mm rear axle spacing, 3D contoured Rubber frame protection, Shimano STEPS compatible
  • Drive System: Shimano STEPS EP8, 250W, 85Nm
  • Battery: Shimano E8036, 630Wh
  • Display: Shimano EM800
  • Assist Switch: Shimano EM800-L
  • Fork: Fox 38 Float, 29”, Performance Elite Series, Grip 2 Damper, 170mm, 44mm Offset, BOOST, 1.5T Steerer, 68mm Crown, Black (SHORT ID: D6G2)
  • Shock: Fox Float X2, Performance Series, EVOL, 2 Position lever, Custom CL, RM, Rezi CM tune, 230x62.5mm, Bearing End, 2x 0.3 spacer fitted. (SHORT ID: D7JK)
  • Front Wheel: DT Swiss H1900 SPLINE,29", 6 Bolt, 110x15mm
  • Rear Wheel: DT Swiss H1900 SPLINE, 27.5", 6 Bolt, Shimano Microspline Driver, 148x12mm
  • Tyres: Front: Maxxis Assegai 29”x2.5 WT 3C MaxxGrip/DD/TR; Rear: Maxxis High Roller II 27.5”x2.5 WT 3C MaxxTerra/DD/TR
  • Crankset: Shimano EM600,165mm, 34T, 52mm Chainline
  • Shifter: Shimano SLX M7100-IR, 12-speed Rapidfire Plus, I-Spec EV
  • Rear Derailleur: Shimano SLX M7100, SGS 12-Speed, Shadow Plus
  • Chain: Shimano SLX M7100 HG 12-speed Inc Quicklink
  • Cassette: Shimano SLX M7100-12, 12-Speed (HYPERGLIDE+), 10-51T
  • Chain Guide: Shimano EM800 drive unit mount
  • Brakes: Shimano SLX M7120, 4 Pot Brake, Metallic Pads with Fins
  • Front Rotor: 203mm
  • Rear Rotor: 203mm
  • Handlebars: Nukeproof Horizon V2 25mm Rise, Width - S780mm, M780mm, L800mm, XL800mm, XXL800mm)
  • Stem: Nukeproof Horizon, 50mm, Black
  • Saddle: Nukeproof
  • Seatpost: Brand X Ascend internal w Shimano SL-MT500-IL Remote lever, S:125mm drop; M:150mm drop; L/XL/XXL:170mm drop
  • Headset: Acros AZX-589R1, sealed bearings, ZS56/28.6 – ZS66/40
  • Grips: Nukeproof Sam Hill Signature
  • Battery Charger: Shimano E6002
  • Certification: EN 15194 Compliant
  • Weight: 24.3Kgs/53.5lbs (Tubeless)
7.199,00 € VHB
Antwort in: 1,1 d
Bewertungen: 12 (67%)
Vertrauen: 0
Momentane Betrachter 1
Veröffentlicht 05.02.2022 11:23
Endet 05.02.2023 11:23
Angesehen 795 ×
Anzahl 1
Hersteller Nukeproof
Zustand neu
Abholung Ja
Ort Dresden
Gewicht 24,3Kg
Farbe Bullet Grey
Rahmengröße M
Motor Shimano
Akku-Kapazität 630 Wh
Federweg vorn 170 mm
Federweg hinten 170 mm
Dämpfer-Einbaumaße 230 x 60 mm Metric
Laufradgröße 29"
Material Aluminium
Gänge 12
Händler Ja
Land Deutschland de
Akzeptierte Bezahlmethoden PayPal, Überweisung
