Shimano SC-M9050 XTR Di2 System Information Display 31.8mm Clamp
Fotos: Shimano SC-M9050 XTR Di2 System Information Display 31.8mm Clamp
Artikelbeschreibung: Shimano SC-M9050 XTR Di2 System Information Display 31.8mm Clamp
Di2 shifting creates an entirely new level of rider options and control. The digital E-tube platform also allows the inclusion of the SC-M9050 Display Unit.
With a quick glance, you can monitor your important Di2 data: gear selection, battery level and shift mode. The expandable E-tube platform also means that integration with electric-controlled suspension from Fox is a reality. All this data at a glance means that you can focus more of your attention on the trail ahead.
- Multiple simultaneous display fields
- Battery level
- Gear position
- Shift mode (Synchronized or Manual)
- Fox SUS position (Climb, Trail or Descend)
- Shimano Synchronized Shift mode switch
- Change between S1, S2 and Manual shift modes
- Audible Shimano Synchronized shift notification tone
- Precision derailleur adjustment
- Easy access adjustment mode
- Numerical adjustment indicator
- Junction A function
- Battery charging port
- Three E-tube wiring ports
- Clamp 31,8 mm
- 30 grams
automatisch übersetzt
Shimano SC-M9050 XTR Di2 System Information Display 31.8mm Clamp kaufen
80 €
Details & Spezifikationen : Shimano SC-M9050 XTR Di2 System Information Display 31.8mm Clamp
Anzahl | 1 |
Hersteller | Shimano |
Zustand | neu |
Versandkosten | 10 € |
Abholung | Nein |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 328 × |
Momentane Betrachter | 1 |
Veröffentlicht | 17. Jul 2024 22:06 |
Endet | 17. Jul 2025 22:06 |
