Shimano BL-RS600/BR-RS405 Rear Disc Brake Flat Mount J-Kit I-Spec II
Fotos: Shimano BL-RS600/BR-RS405 Rear Disc Brake Flat Mount J-Kit I-Spec II
Artikelbeschreibung: Shimano BL-RS600/BR-RS405 Rear Disc Brake Flat Mount J-Kit I-Spec II
Shimano road bike disc brake consisting of the BL-RS600 I-Spec II brake lever at 105 level and the BR-RS405 Flat Mount caliper at Tiagra level. The result of the combination is a solid brake performance in any condition. Trouble-free maintenance is provided by the proven One Way Bleeding concept and the Easy Hose Joint System which simplifies brake hose exchanges.
I-Spec II
I-Spec II is an integrated mounting system for brake and shifting levers. It just needs one bracket which saves space, provides a cleaner optic and saves about 10 grams of weight. Furthermore the adjustability in horizontal direction offers an optimized individual setup.
J-Kit (Easy Hose Joint System)
At brake systems with J-Kit hose joint the brake lever features an integrated olive what makes an easy brake hose installation and removal possible.
Shimano BL-RS600 brake lever
The Shimano BL-RS600 is hydraulic flatbar brake lever at 105 level for fitness bikes providing an optimized braking power curve and stable brake performance. The 3-finger brake lever is more comfortable for daily use. I-Spec II compatible.
Shimano BR-RS405 disc brake caliper
The hydraulic Shimano BR-RS405 disc brake caliper at Tiagra level features the recent Flat Mount installation standard for road and cross bikes. Its 2-piston construction provides consistent braking performance in all weather conditions.
Material:
lever: aluminium (anodized)
master cylinder, caliper: aluminium (painted)
pistons: resin
hardware: stainless steel, steel
Content of delivery:
rear hydraulic disc brake set:
The brake is brand new, OEM, and is delivered like in the photos, without retail packaging. The brake lever has a couple of scratches from storage, that won't be visible after install. Please check the last photo for details.
I-Spec II
Material:
pistons: resin
- BL-RS600 brake lever Right side
- BR-RS405 caliper incl. Resin brake pads
- SM-BH59 brake hose (filled)
Shimano BL-RS600/BR-RS405 Rear Disc Brake Flat Mount J-Kit I-Spec II kaufen
70 €
Details & Spezifikationen : Shimano BL-RS600/BR-RS405 Rear Disc Brake Flat Mount J-Kit I-Spec II
Anzahl | 1 |
Hersteller | Shimano |
Zustand | neu |
Versandkosten | 10 € |
Land |
Rumänien |
Abholung | Nein |
Farbe | Black |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 1.101 × |
Momentane Betrachter | 1 |
Veröffentlicht | 29. Jul 2024 16:43 |
Endet | 29. Jul 2025 16:43 |
