Shimano SLX FC-M7100-2 crankset 36/26T. 2x12-speed, 170mm
Fotos: Shimano SLX FC-M7100-2 crankset 36/26T. 2x12-speed, 170mm
Artikelbeschreibung: Shimano SLX FC-M7100-2 crankset 36/26T. 2x12-speed, 170mm
The SLX FC-M7100-2 crank features an entirely new construction, using direct mount chainrings, special gear tooth profile for improved chain retention, and a 172mm Q-factor.
Features
Hollow-forged crank maximizes power transfer while limiting weight
Exchangeable single/double chainring
Crankset can be used as common component
Extra wide range with front double 36-26T
Benefits
Smoother driving even over bumpy terrain
Rigid and lightweight design boosts trail-riding enjoyment
Q-factor: 172 mm
Chainline: 48.8 mm
Rider tunable
Easier gearing than racing groupsets
Specifications
Weight: 677 g
Chain line: 48.8
Chain ring combination: 36-26T
Compatible BB type: Outboard
Compatible chain: HG 12-speed
Crank Arm Length: 170 mm
Gear arms: 4 arm
HOLLOWTECH II: Yes
Optional Chain Guard: Without chain/bash guard
P.C.D.: Direct Mount
Rear speeds: 12 (Front double)
Threaded BB Shell Width: 68 mm, 73 mm
Q-factor: 172mm
The crankset is brand new, in the original box.
I accept payment thru bank transfer and Revolut.
Features
Benefits
Q-factor: 172 mm
Chainline: 48.8 mm
Rider tunable
Specifications
Weight: 677 g
Chain line: 48.8
Gear arms: 4 arm
HOLLOWTECH II: Yes
Q-factor: 172mm
Shimano SLX FC-M7100-2 crankset 36/26T. 2x12-speed, 170mm kaufen
100 €
Details & Spezifikationen : Shimano SLX FC-M7100-2 crankset 36/26T. 2x12-speed, 170mm
Anzahl | 1 |
Hersteller | Shimano |
Modell | Shimano SLX |
Zustand | neu |
Versandkosten | 15 € |
Land |
Rumänien |
Abholung | Nein |
Gewicht | 677 g |
Kurbelstandard | Hollowtech II |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 507 × |
Momentane Betrachter | 1 |
Veröffentlicht | 7. Aug 2024 17:40 |
Endet | 7. Aug 2025 17:40 |
