Specialized S-Works Stumpjumper Evo S4
Artikelbeschreibung: Specialized S-Works Stumpjumper Evo S4
SPECIALIZED S-Works Stumpjumper Evo
SRAM XX Eagle Wireless Electronic Groupset
FOX Factory Suspension
160/150mm Travel
Hersteller UVP € 11.000,-
2x Benutzt, Bike kommt mit Rechnung und ist versichert!
RAHMEN Größe S4
entspricht etwa Medium bis Large
für Körpergröße von 173 - 188cm empfohlen
GEWICHT lt Hersteller für Größe S4:
13.82kg
FACT 11m carbon chassis and rear-end, asymmetrical design, 29/27.5 Trail Geometry,
SWAT Door integration, head tube angle adjustment, horst pivot BB adjustment, threaded BB,
fully enclosed internal cable routing, 12x148mm dropouts,
sealed cartridge bearing pivots, replaceable derailleur hanger,
150mm of travel
SATTELSTÜTZKLEMME
Alloy, 38.6mm
DÄMPFER
FOX FLOAT X Factory, Rx Trail Tune, EVOL Air sleeve, 2
-position lever w/ LSC adjustment, S1:210x50mm, S2-S6:210x55mm
GABEL
FOX FLOAT 36 Factory, GRIP2 damper, 15x110mm, 44mm offset,
S4: 160mm of travel
SATTEL
Bridge, 155/143mm, Hollow Ti-rails
SATTELSTÜTZE
RockShox Reverb AXS, 30.9, 1X remote, S4: 170mm
VORBAU
OneUp, 35.0
LENKER
OneUp Carbon, riser bar, 5-degree upsweep, 8-degree backsweep, 35mm rise, 800mm, 35.0mm
LENKERGRIFFE
Deity Lockjaw
BREMSE VORNE & HINTEN
SRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm HS2
SCHALTHEBEL
SRAM Eagle AXS Rocker Paddle
SCHALTWERK
SRAM XX1 Eagle AXS
KASSETTE
Sram XG-1299, 12-Speed, 10-52t
KETTE
SRAM XX1 Eagle
KURBELGARNITUR
SRAM X01 Eagle, DUB, 170mm
KETTENBLÄTTER
32T
INNENLAGER
SRAM DUB, BSA 73mm, Threaded
FELGEN
Roval Traverse SL 29F/27.5R, hookless carbon, 30mm inner width, 2Bliss Ready, hand-built, 28h
VORDERRADNABE
Roval Traverse SL, sealed cartridge bearings, 15mm thru-axle, 110mm spacing
HINTERRADNABE
Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing
VORDERREIFEN
Butcher, GRID TRAIL casing, GRIPTON T9 compound, 2Bliss Ready, 29x2.3"
SPEICHEN
DT Competition Race
HINTERREIFEN
Eliminator, GRID TRAIL casing, GRIPTON T7 compound, 2Bliss Ready, 27.5 x 2.3"
Specialized S-Works Stumpjumper Evo S4 kaufen
5.555 € VHB
Details & Spezifikationen : Specialized S-Works Stumpjumper Evo S4
Anzahl 1
Hersteller Specialized
Modell Specialized Stumpjumper
Zustand gebraucht, wie neu
Versandkosten 50 €
Land Österreich at
Abholung Ja
Gewicht 13,82kg
Rahmengröße Other
Federweg vorn 160 mm
Federweg hinten 150 mm
Dämpfer-Einbaumaße 210 x 55 mm Metric
Laufradgröße Mullet 29" / 27,5"
Material Carbon
Angesehen 1.870 ×
Momentane Betrachter 1
Veröffentlicht 16. Okt 2024 08:48
Endet 16. Okt 2025 08:48
