Pivot Cycles SHUTTLE SL PRO X01 Transmission
Fotos: Pivot Cycles SHUTTLE SL PRO X01 Transmission
6.600 €
Artikelbeschreibung: Pivot Cycles SHUTTLE SL PRO X01 Transmission
As NEW lightweight mountain electric bike Pivot Shuttle SL Pro X01, 2.6.2023
In WARRANTY - 2.6.2025!!
Bike comes with NEW Float X (never used as bike had coil from 1st day)!
Complete protective wrap - custom!
- Motor: FAZUA Ride 60 60 Nm
- Battery: FAZUA Energy 430 Wh
- Display: FAZUA LED HUB
- Fork: FOX 36 Factory GRIP2 150 mm, UPGRADE >> 160mm
- Rear Shock: FOX FLOAT X Factory 132 mm
- Seatpost: FOX Transfer Factory 175 mm
- Brakes: UPGRADE >> Hayes Dominion A4
- Drivetrain: Sram X01 Transmission
- Stem: Phoenix Team Enduro/Trail 40 mm
- Handlebar: Phoenix Team Low Rise Carbon 780 mm
- Wheelset: NEWMEN EVOLUTION SL A.30 Alu 29"
- Tires: MAXXIS DISSECTOR 3C MaxxTerra EXO / MAXXIS DISSECTOR 3C MaxxTerra EXO 2.4/2.4
Pivot Cycles SHUTTLE SL PRO X01 Transmission kaufen
6.600 €
Details & Spezifikationen : Pivot Cycles SHUTTLE SL PRO X01 Transmission
Anzahl | 1 |
Hersteller | Pivot Cycles |
Modell | Pivot Shuttle |
Zustand | gebraucht, wie neu |
Land |
Slowenien |
Abholung | Ja |
Ort | Ljubljana - Slowenien |
Rahmengröße | M |
Motor | Fazua |
Federweg vorn | 160 mm |
Federweg hinten | 136 mm |
Dämpfer-Einbaumaße | 185 x 55 mm Trunnion |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 12 |
Angesehen | 1.994 × |
Momentane Betrachter | 1 |
Veröffentlicht | 12. Nov 2024 11:43 |
Endet | 12. Nov 2025 11:43 |
