Propain 2021 Tyee AL 27,5" M
Fotos: Propain 2021 Tyee AL 27,5" M
1.850 €
Artikelbeschreibung: Propain 2021 Tyee AL 27,5" M
For sell my propain Tyee bike:
-Frame: propain Tyee 2021. Size M. No cracks, dents. Visual conditon is very good. frame after servicing ( bearings lubricated with peatys grease). Frame has special protection tape. Rear travel is 160mm
-Rear shock: rock shox super deluxe ultimate coil ( comes with 400,450 and 500lbs spring rate) with fox or rock shox eylet bushings. Fox bushings have better rotation in eylet.
- Fork: fox 36 kashima grip 2 ( 2022 model year). Very good visual and technical condition. Comes with new skf dual compund seal kit and dust wipers. All stanchions without scrathes and scuffs. Steerer tube lengt ~ 18cm. travel 170mm. Comes with new original fox blue stickers.
- Wheelset: stans flow mk3 with stans neo hubs. Regreased and cleaned regularly. 27,5 inches size. rear hub 148*12.
- crankset: truvativ descedant
- sram deraileur and shifter.
* note: comes without hope tech brakes, renthal bar/ stem
As for the bike. This is very capable and strong frame which allows to hit big stuff or dh riding. You won't regret buying it
Located in Latvia-Riga but shipping within continent would be possible. Accept paypal.
Propain 2021 Tyee AL 27,5" M kaufen
1.850 €
Details & Spezifikationen : Propain 2021 Tyee AL 27,5" M
Anzahl | 1 |
Hersteller | Propain |
Modell | Propain Tyee |
Zustand | neu |
Versandkosten | 30 € |
Land |
Lettland - Latvia |
Abholung | Ja |
Ort | |
Gewicht | 16,5 |
Farbe | Turquoise |
Rahmengröße | M |
Federweg vorn | 160 mm |
Federweg hinten | 170 mm |
Steuerrohr | Tapered 1⅛″/1,5″ |
Steuerrohr-Länge | 120 mm |
Dämpfer-Einbaumaße | 210 x 55 mm Metric |
Laufradgröße | 27,5" / 650b |
Material | Aluminium |
Gänge | 12 |
Angesehen | 1.397 × |
Momentane Betrachter | 1 |
Veröffentlicht | 2. Dez 2024 21:37 |
Endet | 2. Dez 2025 21:37 |
