Rocky Mountain Element
Artikelbeschreibung: Rocky Mountain Element
Selling a Rocky Mountain Element frame set in size XL. This is an excellent downcountry bike that combines the efficiency of an XC bike with a trail/all-mountain geometry. It can handle everything from XC racing to demanding trails.
The frame has space for two full-size 750ml bottles, making it a great endurance bike as well. Fully guided internal cable routing ensures easy installation—just insert the cable, and it comes out on the other side. Rubber frame protection in multiple areas ensures a super-quiet ride even in rough terrain. The frame with the shock weighs 2,400g in this size (measured).
Everything is in excellent condition, with only minor scratches from regular use, which are documented in the photos. Protective film was applied to exposed areas. A purchase receipt is available, and since the frame is unregistered, the 5-year extended warranty can be transferred to your name.
Included in the price:
Frame set
Rear axle
Seat clamp
FOX FLOAT Factory DPS shock (with compression adjustment and a full set of tokens)
If you decide quickly, I will also include a Cane Creek Hellbender 70 headset. There's also an option to buy it as a set with a FOX Float 34 Factory 130mm GRIP2 2024 fork, including purchase documents.
automatisch übersetzt
Rocky Mountain Element kaufen
1.990 € VHB
Details & Spezifikationen : Rocky Mountain Element
Anzahl 1
Hersteller Rocky Mountain
Modell Rocky Mountain Element
Zustand gebraucht, wie neu
Versandkosten 20 €
Abholung Ja
Ort Prague - Tschechien
Rahmengröße XL
Dämpfer-Einbaumaße 190 x 45 mm Metric
Laufradgröße 29"
Material Carbon
Angesehen 2.825 ×
Momentane Betrachter 1
Veröffentlicht 1. Feb 2025 10:09
Endet 1. Feb 2026 10:09
