Cannondale SuperSix EVO 1 Cashmere Gr.: 56 Modell 2025
Fotos: Cannondale SuperSix EVO 1 Cashmere Gr.: 56 Modell 2025
6.999 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Cannondale SuperSix EVO 1 Cashmere Gr.: 56 Modell 2025
- Cannondale SuperSix EVO 1 Cashmere Modell 2025
- Farbe: Cashmere
- Rahmen: SuperSix EVO Carbon, integrated cable routing w/ Switchplate, 12x142 Syntace thru-axle, BSA 68mm threaded BB, flat mount disc, integrated seat binder, SmartSense compatible
- Gabel: SuperSix EVO Carbon, integrated crown race, 12x100mm Syntace thru-axle, flat mount disc, internal routing, 1-1/8" to 1-1/4" Delta steerer, 55mm offset (44-54cm), 45mm offset (56-61cm)
- Felgen: HollowGram R-S 50, Carbon, 20h front, 24h rear, 50mm deep, 21mm inner width, tubeless ready
- Naben: (VR) HollowGram, sealed bearing 12x100mm centerlock / (HR) HollowGram, 12x142mm centerlock w/ DT Swiss 350 internals
- Speichen: Formula Grand Forza, Double Butted, straight-pull
- Reifen: Vittoria Rubino Pro Bright Black, 700x25c, reflective strip
- Pedale: Not included
- Kurbel: SRAM Force, DUB, 48/35
- Tretlager: SRAM DUB BSA
- Kette: SRAM Force, 12-speed
- Zahnkränze: SRAM XG-1270, 10-33, 12-speed
- Umwerfer: SRAM Force AXS, braze-on
- Schaltwerk: SRAM Force AXS
- Schalthebel: SRAM Force AXS, 12-speed
- Lenker: Vision Trimax Carbon Aero
- Griffe: Cannondale Bar Tape, 3.5mm
- Vorbau: Cannondale C1 Conceal, Alloy, 31.8, -6°
- Steuersätze: Integrated, 1-1/8" - 1-1/4"
- Bremsen: SRAM Force AXS Hydraulic Disc, 160/160mm PaceLine Rotors
- Sattel: Prologo Dimension TiRox NDR, Titanium Rails
- Sattelstütze: Cannondale C1 Aero 40 Carbon, 0mm offset (44-48cm), 20mm offset (51-61cm)
- Größen44, 48, 51, 54, 56, 58, 61
- Extra(s)SRAM AXS charger
Pflichtangaben nach GPSR
Weitere Angaben sind eventuell in den Produktbildern enthalten.
Cannondale SuperSix EVO 1 Cashmere Gr.: 56 Modell 2025 kaufen
6.999 €
Details & Spezifikationen : Cannondale SuperSix EVO 1 Cashmere Gr.: 56 Modell 2025
Anzahl | 1 |
Hersteller | Cannondale |
Modell | Cannondale Supersix Evo |
Zustand | neu |
Land |
Deutschland |
Abholung | Ja |
Ort | |
Rahmengröße | 56 cm |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 762 × |
Momentane Betrachter | 1 |
Veröffentlicht | 7. Feb 2025 11:19 |
Endet | 7. Feb 2026 11:19 |
