Unno Mith Elite custom Bosch powered 750Wh E-Bike Enduro in L, NEU!!
5.199 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Unno Mith Elite custom Bosch powered 750Wh E-Bike Enduro in L, NEU!!
Verkauf aus Händler mit Rechnung und Garantie
Besucht auch unseren Webshop www bikeinsel com für weitere super Angebote , oder kontaktiert uns direkt via Telefon oder Email
Frame: Carbon fibre monocoque with 160mm of rear travel. Virtual pivot suspension system. Integrated display, battery, chain guide and seat tube clamp. Motor protector. EnduroMAX Bearings. Internal cable routing. Boost thru axle 12×148. Post Mount brake system. Max tire width: 2.6”. Oceanworks recycled plastic parts. Recycled rubber protectors. Recommended sag: 35% (+/- 5%).
Motor: Bosch Performance Line CX Bosch Smart System. Comptabile with Bosch Connectmodule. 85Nm. Rim Magnet.
Battery: Bosch 750Wh integrated.
Display: Bosch KIOX 300 Integrated screen. Navigation functions.
Controller: Bosch Remote LED Control Unit BRC3600 Smart System.
Headset: Acros Internal Cable Routing IS52. 1.5 / 1.5, with Acros spider with entry ports for cable routing.
Fork: Rockshox ZEB Select Charger RC, Debonair+ and 38mm stanchions.
Rear Shock: Fox Float X2 Factory Kashima 2-position-adjust 230x65mm.
Rear Derailleur: SRAM GX Eagle 12 speed. Mechanical. X-Actuation. Colour: Lunar. Cage material: aluminum. Pulley bearings: steel.
Trigger: SRAM GX Eagle 12 speed. Mechanical. X-Actuation.
Cassette: SRAM GX XG 1275. 500% Range. 10-50. Finish: black. X-Glide 2.
Crankset: SRAM GX Eagle Alloy. Lunar. 12 speed.
Chainring: E*Thirteen E*spec Aluminium, 36T, Bosch Gen4 Direct Mount.
Chain: SRAM GX Eagle technology. 120 links. Solid pin.
Wheelset: DT Swiss H1900 Spline Mullet. 29″ front and 27.5″ Rear. 30mm inner width. E-bike specific. DT 370 Hub.
Front Tyre: Maxxis Assegai 29x2.5" 3c maxxgrip tlr
Rear tyre: Maxxis Minion DHR II 27.5x2.4" 3c maxxterra tlr
Brakes: Formula Cura 4 4x18mm pistons on Caliper. SRAM Mixmaster. Sintered Pads. Axial Master Cylinder. Forged Aluminium. 850mm front hose and 2000mm rear hose.
Discs: Formula Monolitic 220mm front and 203mm rear rotors. Thickness: 2.35mm. Extreme lateral stiffness, anti-noise and anti-vibrations design.
Handlebar: E*Thirteen Base Alloy. 35mm.
Stem: E*Thirteen Base Alloy. 35mm.
Dropper: OneUp V3 150mm remote
Saddle: Selle Italia SLR Boost.
Größe S2 (entspricht Large)
UVP 9295€
Pflichtangaben nach GPSR
Weitere Angaben sind eventuell in den Produktbildern enthalten.
Unno Mith Elite custom Bosch powered 750Wh E-Bike Enduro in L, NEU!! kaufen
5.199 €
Bikeinsel at Gewerbliche/r Anbieter*in
Antwort in: 5 h
Bewertungen: 519 (95%)
Vertrauen: 7
Details & Spezifikationen : Unno Mith Elite custom Bosch powered 750Wh E-Bike Enduro in L, NEU!!
Anzahl 1
Hersteller Unno
Zustand neu
Land Österreich at
Abholung Ja
Gewicht 22,9kg
Farbe Türkis/Weiss
Rahmengröße L
Motor Bosch
Akku-Kapazität 750 Wh
Federweg vorn 170 mm
Federweg hinten 160 mm
Dämpfer-Einbaumaße 230 x 65 mm Metric
Laufradgröße Mullet 29" / 27,5"
Material Carbon
Gänge 12
Akzeptierte Bezahlmethoden PayPal, Überweisung
Angesehen 1.413 ×
Momentane Betrachter 1
Veröffentlicht 14. Feb 2025 13:56
Endet 14. Feb 2026 13:56
