Commençal Meta SX V4 Small Frameset
Fotos: Commençal Meta SX V4 Small Frameset
Mehr Fotos anzeigen
1.300 €
Artikelbeschreibung: Commençal Meta SX V4 Small Frameset
I'll be honest, it's a good bike, but after riding it for a while, I'm looking for something else. A little less slack, something with an high pivot... in short, Im looking for Forbidden Druid (maybe Dreadnought, Deviate?) the most..i am open to swap.
Frame arrived to me through direct sales in May 2022, it was riden the whole time, until 8/2024, when i get a trail bike (T.E.M.P.O.) It had a regular service (by me..from heart and OCD - every service/change on "service sheet")... nothing squeaks, just silent, more info below:
Main geo: (for 158-170 cm body height)
reach: 436
top tube: 570
stack: 633
HA: 63,6
SA: 78,1
wheelbase: 1232
chainstay: 443
seat tube dia: 34,9
Frame condition:
A couple of scratches, mostly on the rear triangle. Foil on exposed places.
Bearings in good condition: 1/2024 - main pivot bearings (6804) replaced, 2 pcs 3802 replaced, other 6pcs 3802 cleaned with new grease. Since then, it has been riden minimally, so it still moves smoothly.
Headset assembly - new upper bearing. No play or creaking.
BB - the same, original, still ok. Cranks also included in the price, scratched but functional. 170mm, SRAM X1 1000, 32 tooth Alu chainring.
Also included new spare derailleur hanger, rubber hose/bowden frame plugs..
Frameset contains a shock - DVO Jade X with springs - DVO ls 450 (linear), DVO progressive rate 425-500, Cane Creek progressive 400-488. (+ New service kit)
For additional 130€ you can get OneUp V2 180mm dropper post (has some polished scratches but works just fine..)
reach: 436
top tube: 570
stack: 633
HA: 63,6
SA: 78,1
wheelbase: 1232
chainstay: 443
seat tube dia: 34,9
Frame condition:
automatisch übersetzt
Commençal Meta SX V4 Small Frameset kaufen
1.300 €
Details & Spezifikationen : Commençal Meta SX V4 Small Frameset
| Anzahl | 1 |
| Hersteller | Commençal |
| Modell | Commencal Meta SX |
| Zustand | gebraucht |
| Versandkosten | 80 € |
| Land |
Slowakei |
| Abholung | Ja |
| Ort | |
| Farbe | Heritage Green |
| Rahmengröße | S |
| Federweg vorn | 160 mm |
| Federweg hinten | 170 mm |
| Steuerrohr | Tapered 1⅛″/1,5″ |
| Steuerrohr-Länge | 115 mm |
| Dämpfer-Einbaumaße | 230 x 65 mm Metric |
| Laufradgröße | Mullet 29" / 27,5" |
| Material | Aluminium |
| Angesehen | 2.933 × |
| Momentane Betrachter | 1 |
| Veröffentlicht | 20. Feb 2025 07:38 |
| Endet | 20. Feb 2026 07:38 |
