EXT Storia V4 coil shock standard and trunnion mount
Fotos: EXT Storia V4 coil shock standard and trunnion mount
999 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: EXT Storia V4 coil shock standard and trunnion mount
please choose dimensions (length and stroke) for any trunnion and standard mount
please tell us your BIKE, RIDER WEIGHT and RIDER STYLE, the fork will be adjusted to your personal setup!!
coil spring is not included!!
available METRIC STANDARD:
210 / 47.5 mm
210 / 50 mm
210 / 52.5 mm
210 / 55 mm
230 / 57.5 mm
230 / 60 mm
230 / 62.5 mm
230 / 65 mm
250 / 67.5 mm
250 / 70 mm
250 / 72.5 mm
250 / 75 mm
available METRIC TRUNNION:
185 / 47.5 mm
185 / 50 mm
185 / 52.5 mm
185 / 55 mm
205 / 57.5 mm
205 / 60 mm
205 / 62.5 mm
205 / 65 mm
225 / 67.5 mm
225 / 70 mm
225 / 72.5 mm
225 / 75 mm
- 4 way adjustable (LSC-HSC-LSR-HBC)
- Unique patent pending PSR technology to avoid harsh top-out while improving bike platform stability
- New externally adjustable HBC Technology: no more bottom-out
- Allen key adjuster for both high and low compression valve
- LOK 2.0: optimized for every trail section
- High turbolent flow valves: no risk of cavitation
- Ø14 mm high strength chrome steel shaft with DLC ultra-low friction surface coating to increase durability
- Spring Thrust Bearings to improve straight alignment in case of spring side-load conditions
- Reservoir with large volume bladder design and very low reservoir pressure (55PSI) for maximum sensitivity
- New high viscosity index EV2S fluid developed throughout our off-road motorsport experience
- 30% lighter steel spring, designed from motorsport and tested to perform over 500,000 cycles
- Unique frequency dependent 1 way valve for best ride quality on rough terrain
- Wider and improved adjustment range with more defined sensitivity
- Weight: 397 gr. (210×55 mm. Standard mount – without spring)
210 / 47.5 mm
210 / 50 mm
210 / 52.5 mm
210 / 55 mm
230 / 57.5 mm
230 / 60 mm
230 / 62.5 mm
230 / 65 mm
250 / 67.5 mm
250 / 70 mm
250 / 72.5 mm
250 / 75 mm
185 / 47.5 mm
185 / 50 mm
185 / 52.5 mm
185 / 55 mm
205 / 57.5 mm
205 / 60 mm
205 / 62.5 mm
205 / 65 mm
225 / 67.5 mm
225 / 70 mm
225 / 72.5 mm
225 / 75 mm
Pflichtangaben nach GPSR
Herstellerinformationen (EU)
Extreme Racing Shox
Viale del Lavoro 66/68,
36048 Ponte di Barbarano VI
+39 0444 730635
info@extremeshox.com
+39 0444 730635
Herstellerinformationen (außerhalb EU)
Extreme Racing Shox
+39 0444 730635
+39 0444 730635
Weitere Angaben sind eventuell in den Produktbildern enthalten.
EXT Storia V4 coil shock standard and trunnion mount kaufen
999 €
Details & Spezifikationen : EXT Storia V4 coil shock standard and trunnion mount
Anzahl | 1 |
Hersteller | EXT |
Hersteller-Informationen (falls in EU ansässig) | Extreme Racing Shox Viale del Lavoro 66/68, 36048 Ponte di Barbarano VI +39 0444 730635 info@extremeshox.com |
Hersteller-Informationen (falls nicht in EU ansässig) | Extreme Racing Shox Viale del Lavoro 66/68, 36048 Ponte di Barbarano VI +39 0444 730635 info@extremeshox.com |
Zustand | neu |
Land |
Österreich |
Abholung | Ja |
Ort | |
Dämpfer-Typ | Stahlfeder |
Dämpfer-Einbaumaße | Sonstige |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 635 × |
Momentane Betrachter | 1 |
Veröffentlicht | 27. Mär 2025 10:55 |
Endet | 27. Mär 2026 10:55 |
